Bronco II Ford Bronco II
Buckin'BroncoII
Old Feb 4, 2005 | 03:13 PM
DirtyPiggyBII's Avatar
DirtyPiggyBII
Buckin'BroncoII
Hi, all.. I have an '87 BII 4X4/ 2.9 V6 engine. I drive it frequently but the last time I drove it, drove fine, and parked it. The next time I went to crank it, it wouldn't start. It has gas in it, and battery is new. The starter will turn the motor over just fine, but will not hit. If I wait and try again the next day, the motor will hit briefly, but not start and then back to the old not hitting. (?)
Thanks for any and all input.
Old Feb 4, 2005 | 05:29 PM
mrshorty's Avatar
mrshorty
It has gas in the tank, but is that gas getting to the engine? Best way to check is to put a fuel pressure gauge on the fuel rail and see if it has any pressure. In the absence of a gauge, can you hear the fuel pumps running?
2nd thing to check is for spark to the spark plugs. Tell which of the two (fuel and/or spark) the engine isn't getting, then we can go from there to figure out why it won't start.
Old Feb 5, 2005 | 03:02 PM
RomerB2's Avatar
RomerB2
Check the inertia switch too.
Old Feb 5, 2005 | 04:04 PM
Broncoitis's Avatar
Broncoitis
I agree with mrshorty you need to determine if the problem is fuel or spark, If you dont have a fuel pressure gauge the easiest way to tell if fuel is getting to the injectors is by taking the cap off the valve on top of the injector rail and depressing it briefly with a small screw driver or other pointed object,Also be sure not to look directly at it as it should spray fuel.
