Bronco II Ford Bronco II
egr woes
Old Feb 4, 2005 | 07:58 PM
Monty06's Avatar
Monty06
Cool egr woes
i have 2 questions about the egr system
my egr's metal line is rusted off on both sides by my manifold and my valve entrance. what might or has already happened to my truck?
without having my egr working
i have heard about detonating what is that ?
Old Feb 4, 2005 | 09:52 PM
mrshorty's Avatar
mrshorty
Detonation (aka spark knock or ping) is a condition where the fuel mixture burns (for lack of a better description) awkwardly and too soon. If you want a more detailed description, a google search should yield several potential articles that will describe in more technical detail what detonation is. The problem is, when the combustion mixture ignites too soon, it is pushing down on the piston while the piston needs to come up. This can destroy the piston. If you don't hear the engine pinging (sounds like a marble rattling around in a can kind of), then you're probably not doing any damage. I would try to find a new EGR tube and fix it, but it's not one of those, "stop the car now and tow it" kind of things, unless the engine is pinging real bad.
Old Feb 4, 2005 | 10:17 PM
Monty06's Avatar
Monty06
hi mrshorty thank you for that info i have a question can't i just use a rubber hose/line and clamp it on to what is left of the pipe. or it that a bad idea
i have been to autozone and all they find is the valve in the parts cat.
is there a name for the tube.
Old Feb 5, 2005 | 09:14 AM
mrshorty's Avatar
mrshorty
Should be EGR tube or something to that effect. It does seem that people have a hard time finding that part -- Might have to settle for the junkyard.
I wouldn't use rubber for that tube -- it sees hot exhaust gases. I'm not sure exactly how hot exhaust manifolds can get, but I expect it's hot enough to "burn rubber "
Tim Hodgson
45
Oct 5, 2015 10:25 AM
digruk
Modular V8 (4.6L, 5.4L)
Feb 26, 2015 08:20 PM
awq134
2009 - 2014 F150
Dec 25, 2014 01:50 PM
F-250 restorer
23
Nov 19, 2012 12:06 AM
shorebird
Feb 16, 2009 09:13 AM
