axle help
Old Feb 4, 2005 | 10:50 AM
Wylieford05's Avatar
Wylieford05
axle help
what are the stock axles on a 94 f250?
Old Feb 4, 2005 | 06:09 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Dana 44HD TTB or Dana 50 TTB front, depending on GVWR. Over 8000 lbs should be the 50.
Ford/Sterling 10.25" rear, manufactured by Visteon (www.visteon.com). It can be full-float or semi-float, depending on GVWR. Semi-float is 5300 lbs GAWR, full-float is 6084 lbs.
TTB = Twin Traction Beam, Ford's fancy name for an independent 4wd frontend.
