1966 - 1977 Early Broncos
9 in rear end
Old Feb 4, 2005 | 08:15 AM
larryejoh's Avatar
larryejoh
9 in rear end
Do all trucks have 31 spline axles? What if any trucks had 28 spline axles? I'm changing my gearing from 4.11 to 3.50 and I am wondering what 9 in to look for out of the junk yard that had 28 splines and 3.50 gear ratio.
Old Feb 4, 2005 | 09:06 AM
2classics's Avatar
2classics
The 66-77 broncos came with 28 and I think in 78 when they went big they got the 31. Not sure on the pickups.
Old Feb 4, 2005 | 01:36 PM
italianrich's Avatar
italianrich
early bronco all had 28 spline, junk yard shopping you need early bronco axles, they were a different length than any other ford, so pickup, van, etc will not work. now I think some of the older mustangs had 28 splines, so if you are lookin for a center section, I think that is what you need, most trucks and vans had 31 splines, so It would not be a drop in conversion, unless you got a 31 spline housing and bought some 31 spline axles( a good upgrade if youre breaking axles anyhow).
Old Feb 5, 2005 | 08:05 AM
larryejoh's Avatar
larryejoh
I only need the center section. Can I swap the spider gears from mine to a 31 spline 3.50 carrier and use my 28 spline axles?
Old Feb 5, 2005 | 06:05 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
A 31 spline will not fit though the end of the carrier or the bearings!
P.s I have ran in to this before ,I ended up going with a full spool that bolted
right in! Make sure that if you plan on trading out carriers that the bearing
bore in the case are of the same size there are 3 sizes .
Old Feb 11, 2005 | 06:07 PM
sps3006's Avatar
sps3006
To answer the question about what has 31 and what has 28 spline in p/u's if I recall properly '73' is the magic number. before 28 after 31. I know my 71 had 28 and my 74,76 and everything else since then where 31.
Old Feb 13, 2005 | 11:09 AM
Pro-Street/StateTK
( SP3006 ) as far as 73 being the magic # I have had enuff 73-79 trks to fill
a parking lot , and have never ran across one of mine that was 31 spline .
I do know there out there ! I just keep missing out on them .
Old Feb 13, 2005 | 10:32 PM
RCrawler's Avatar
RCrawler
It also depends on whether it is a 2 or 4wd and F100 and 150. My 77 4wd has 31 splines, my 76 F100 2wd had 28. A friend has a 75 F100 4wd with 31s and a 76 F100 4wd with 28's. I've never seen a 78 or later 4wd with 28's, but I've seen 2wds both ways into the early 80's.
Jason
