1978 - 1996 Big Bronco
need help
Old Feb 4, 2005 | 01:19 AM
boltmann's Avatar
boltmann
need help
I have a 1991 bronco w/351w....engine builder built it.....distributor gear wearing out extremely fast....2 diferent distributors both stock one remanufactured...changed gears several times....both brass and iron......tried three different cams, first two were comp cams, third cam is an edelbrock cam...engine builder cant figure it out and never heard of this.....lubed the hell out of the gears...after breaking in the cam i pull the dist. and already see the gears getting wore out (sharpening)......has anyone heard of this and how can i fix this....
your help is appreciated
desparate
Old Feb 4, 2005 | 12:45 PM
TxBrokenarrow's Avatar
TxBrokenarrow
are you running a roller cam..i have heard of some issues with a stock distributer(non roller) with a roller cam..
Old Feb 4, 2005 | 01:39 PM
boltmann's Avatar
boltmann
it is a non roller...also switched from hi volume oil pump to stock
Old Feb 4, 2005 | 03:16 PM
TxBrokenarrow
I'm by no means an engine builder but usually the cam manufacture specify what gear to run..you mentioned brass and iron...iron would be cast???maybe you need a steal gear (cnc)if there is such a beast...i'll try to look for you..good luck
Old Feb 4, 2005 | 10:31 PM
boltmann's Avatar
boltmann
the cast gears also grind down the cam as well....so im sure a steel gear will tear up the cam gear
Old Feb 5, 2005 | 04:55 PM
80Bronco94's Avatar
80Bronco94
Could your cam be walking in the block? I have heard of them walking slightly and eat dist gears. just an idea.
Old Feb 6, 2005 | 02:57 AM
boltmann's Avatar
boltmann
already checked that
Old Feb 6, 2005 | 07:04 AM
tex94F250's Avatar
tex94F250
Check the vertical movement on the distributor shaft. I know you have replaced two distributors, but check it anyway. I had a similar issue on my '66 4x4 with a 352 in it as the distributor shaft drove the oil pump and it suffered from vertical displacement. Went through three distributors until I changed to a dual point unit back then. Seems that the dist. would be forced upwards and cause excessive backlash on the drive gear. Just a thought.
Old Feb 6, 2005 | 11:13 AM
80Bronco94's Avatar
80Bronco94
It almost sounds like the cam is either too far back in the block or too far forward. Was the thrust plate replaced?
Old Feb 6, 2005 | 12:04 PM
tex94F250's Avatar
tex94F250
Darn it 80Bronco94, the simplest things are always right in front of you. Super idea for boltman.
tracman
15
Feb 3, 2022 02:54 AM
RadioControlGuy85
Mar 9, 2014 02:19 PM
medino03
Sep 7, 2012 10:16 AM
jarch
Dec 15, 2005 10:53 PM
dpkrizov
Jun 5, 2002 09:31 PM
