Overdrive Problems
Old Feb 3, 2005 | 11:53 PM
MomsExcursion's Avatar
MomsExcursion
Overdrive Problems
On my 2001 X the overdrive light comes on and kicks out of overdrive. You can't push the button to get overdrive back on again. You can turn the motor off and wait awhile then restart it and sometimes it will reset to have the overdrive work and sometimes not. It is a steady light not a blinking light. Any ideas?
Old Feb 4, 2005 | 07:32 AM
Casey's Avatar
Casey
There is a wire in the steering column that is pinched. It's shorting and doing this to you. Take the plastic cover off of the column and you might be able to see it. It it probably near where the column tilts.
