motor swap
Old Apr 8, 2002 | 05:33 PM
Rob B's Avatar
Rob B
Post motor swap
i have a 84 F 250 with a blown up 300 6. i want to put a 351w in it. it also has a 7 1/2 ft fisher plow on it and i live in the hills and want the power to get up the hills with the blade on. i know the gas milege will suck but will it work? or would i be better off with a 302. will that bolt up too? its a 4 speed manual. will either of them motors bolt up to my tranny?thanks
1984 f-250 300 6
1986 f-150 300 6
1971 f-100 302 v8
Old Apr 8, 2002 | 06:20 PM
Mil1ion's Avatar
Mil1ion
motor swap
too bad about the 300.
The 302 will SUCK big time(you might make it up without the balde touching anything)
The 351W will be better but, a done up 400 will be real good for that.
From what you mentioned, the Windsor is best, IMHO
[i][font color=blue]Dennis[/font][i]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[i][font color=green]
http://www.clubfte.com/users/mil1ion/Mil1ion.html [/font][i]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Apr 8, 2002 | 07:04 PM
75SuperCab's Avatar
75SuperCab
motor swap
Does "Bronco Engine Swap" a few posts down answer any of your questions? Good luck.
John
Old Apr 9, 2002 | 08:02 AM
slikness's Avatar
slikness
motor swap
The bell housing on the tranny is the same for the 300, 302 and 351W. You will need to remove the towers mounted on your cross member and get a set of mounts that actually mount behind your cross member for the 302 or 351W. Just build your 351W to give as much torque as you can get...the 302 and 351W are very similar, but I believe you'll get more of what you want from the 351W. Add a cam and try and get some good heads and you should be able to climb them snowbound hills pretty easy.
Old Apr 10, 2002 | 03:20 PM
Rob B's Avatar
Rob B
Post motor swap
thank you to all.
Old Apr 10, 2002 | 03:27 PM
Rob B's Avatar
Rob B
motor swap
i also heard i need to get a different flywheel. is that true?
Old Apr 10, 2002 | 05:52 PM
slikness's Avatar
slikness
motor swap
The flywheel has no imbalance on the 300 and a 28 1/2 oz imbalance on the 351w, so yes the flywheel needs to be changed.
Old Apr 22, 2002 | 01:11 PM
Rob B's Avatar
Rob B
motor swap
thanks again
Old Apr 23, 2002 | 09:20 AM
DoubleA's Avatar
DoubleA
Post motor swap
