Sponsored by: Kumho
brake problem
Old Feb 3, 2005 | 10:36 PM
akpilz2004's Avatar
akpilz2004
brake problem
hey
i have a 84 f150 300 and sometimes when i hit the brakes it goes to the floor and i have to let the peddle come back up and then push it again and the brakes while work fine. it does it every other time i go for the brakes
could it just be air in the lines or do i hve to start replacing stuff
any help would be grateful
dangerous situation
Old Feb 4, 2005 | 04:28 AM
nudgey's Avatar
nudgey
Hi. Bleed the brakes starting from furthest wheel to closest wheel (from brake fluid resevoir), check vaccum connection to brake booster, check for leaks on all 4 wheels, check brake fluid reservoir cap is on poperly (look for "dribbles" of fluid down the side), check all brake lines connections for leakage signs. Make sure you give the brakes a good bleeding. Hope this helps.
Chris
