Best Spark Plugs?
Old Feb 3, 2005 | 02:27 PM
loneleader's Avatar
loneleader
Best Spark Plugs?
I have an '89 E350 with a 5.8L that has been giving me fits. I am going back thru the basics, so, which brand spark plug works best for this rig and is the platinum worth the extra money?
Old Feb 3, 2005 | 03:13 PM
TheWiz427's Avatar
TheWiz427
I use Autolites myself! The platinum plugs are junk and not worth it in my opinion, I tried them once with horrible results.
Old Feb 3, 2005 | 08:33 PM
loneleader's Avatar
loneleader
What type of results did you experience? I use them in my 3.8L T-Bird, and they seem fine. I have them in the 5.8L, but I'm about to pull them to see if I can get rid of lack of power at all RPMS.
Old Feb 4, 2005 | 06:50 AM
TheWiz427's Avatar
TheWiz427
Thats part of the problem i had. When i first put them in it seemed to have a loss of power right off. the other was a slight loss of fuel mileage along with the truck just not seeming to run rught. I pulled them shortly thereafter threw a set of autolites back in no problems.
Old Feb 4, 2005 | 09:39 AM
loneleader's Avatar
loneleader
Thanks, you convinced me. I'll get a set of autolites today.
Old Feb 4, 2005 | 08:27 PM
pfogle's Avatar
pfogle
MOTORCRAFT plugs... My 351 would eat the platinum plugs.
Old Feb 9, 2005 | 10:17 PM
loneleader's Avatar
loneleader
OK! Replaced the platinums with Autolites. Runs better and found #7 had carbon build-up (not fouled) Checked the injector and there was the problem. I am going to run 3M injector cleaner through the fuel rail with a univeral kit, hoping that will loosen her up, otherwise, off comes the top and the injectors go out to be cleaned.
