ZF 5-speed
Old Apr 26, 2002 | 12:08 PM
hybrid F250's Avatar
hybrid F250
ZF 5-speed
Does anyone know what the gear ratios are for the mazda ZF transmission? We are trying to figure the final ratio for our buddys 90 F-350.
thanks
chad
Old Apr 26, 2002 | 06:28 PM
brown 4x4's Avatar
brown 4x4
ZF 5-speed
Mazda makes the 5 speed used in the F-150's, ZF makes the heavy duty 5 speed. There were two sets of ratios in the ZF, but I don't know how to tell which you have.
ZF S5-42 Close Ratio:
R: 3.79
1: 4.14
2: 2.37
3: 1.42
4: 1.00
5: 0.77
ZF S5-42 Wide Ratio:
R: 5.24
1: 5.72
2: 2.94
3: 1.61
4: 1.00
5: 0.76
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old Apr 26, 2002 | 07:42 PM
HotWhlz85's Avatar
HotWhlz85
ZF 5-speed
Old Sep 8, 2010 | 08:30 PM
fordman41291's Avatar
fordman41291
can you put a ZF5 in a F150 behind a 300 I6?
Old Sep 8, 2010 | 09:07 PM
fellro86's Avatar
fellro86
Sure, find one in a 250 that has the 300 or 351W.
Old Sep 8, 2010 | 09:30 PM
fordman41291
yeah a buddy of mine has one that came out of a F150 with a 300 6 do i have to change anything? bellhousing?? change any mounts or anything?
Old Sep 8, 2010 | 09:35 PM
fellro86's Avatar
fellro86
That is why I specified those motors, bell housing is the same pattern (the bell cannot be removed) can't outright answer on any changes beyond that for certain. If the trans came out of a 150, it may still be a Mazda trans rather than the ZF.
Old Sep 8, 2010 | 09:46 PM
93Fodge's Avatar
93Fodge
If its out of a F150, its almost guaranteed to be a M5OD, and not a ZF.
As far as changes, the only major change you might have to do is the clutch release hydraulics.
Old Sep 8, 2010 | 10:35 PM
fordman41291
GOD I HATE THOSE M5OD's WORTHLESS POC TRANNYs
Old Sep 8, 2010 | 11:05 PM
Franklin2's Avatar
Franklin2
99% chance a f150 has the Mazda tranny. Someone on here a long time ago said there was one year where the f150 could be ordered with the zf. On both of these 5 speeds, the bellhousing is made into the tranny. So you have to find the correct tranny to fit your engine, and it has to have a hydraulic clutch.
Old Sep 8, 2010 | 11:08 PM
fordman41291
yeah, I just dont understand why Ford would put a MAZDA POC tranny with a truck that could pull a hell of a load?
Old Sep 9, 2010 | 04:50 PM
85bobtail's Avatar
85bobtail
It's about the $$$$ or giving engineers too much authority.
Engineers should be required to work on their "stuff" before the company puts it out to market. Maybe it will eliminate so much "junk" being dumped on the public.
sorry about drifting from the tranny subject
88svt
Modular V10 (6.8l)
Jan 3, 2021 04:09 PM
Pele
Aug 29, 2016 12:04 PM
97puller
Aug 28, 2010 06:59 AM
Katmandu
26
Nov 5, 2005 09:45 AM
FrameRotBlues
Jul 19, 2005 11:34 PM
