86 F150 302-Need help understanding code scanner
Old Feb 6, 2005 | 10:04 PM
  #31
mdstud's Avatar
mdstud
No but it defintely should build up some pressure during the prime. Try replacing your fuel filter, if the same problem after that then replace the pump.
Old Feb 6, 2005 | 10:48 PM
  #32
79Spitfire's Avatar
79Spitfire
sorry mdstud, i forgot to answer the question about clearing my codes. two ways...one, by disconnecting the negative from my battery for a while . and the second way was with my code scanner, you can clear the memory with it by switching it on then off then on again , something like that.
O.K. the fuel filter was replaced this afternoon and i still have the same results. from what i understand theres a one way valve inside the HP pump that should hold the pressure? So if that valve was stuck open the fuel would just return back to the tank through the same line it came thru to get there? Which makes sense. But what would cause my injectors to not work at all? If the low pressure in-tank pump wasn't working would the high pressure pump still be able to suck fuel from the tank at all? Cause it still has a steady flow of fuel but not at the specified pressure.
Old Feb 7, 2005 | 12:06 PM
  #33
mdstud's Avatar
mdstud
So I'm guessing the injectors aren't firing? put a noid light on the injectors if they aren't being told to fire from the computer then you need to address that problem first before proceding with the fuel system. If the computer isn't sensing a proper signal from the tfi module on the distributor, you will get an error code 18 and the injectors won't fire. But make you really need to test and see if they are being fired. If they are being fired then the problem is just the fuel pressure. The computer has no input for fuel pressure so it doesn't care if the fuel pump aren't working it will still open and close the injectors. To isolate the fuel problem, disconnect the high pressure pump and have an assistant turn the key on while you listen for the low pressure pump operation, try both the front and rear tanks if you don't hear either then it's possible they're both bad. If they are working then replace the high pressure pump.
Old Feb 7, 2005 | 12:15 PM
  #34
79Spitfire's Avatar
79Spitfire
Thank you so much mdstud. Is it possible to test the injectors with a volt/ohmmeter? If not i can go buy a noid light thats no biggie.
Old Feb 7, 2005 | 03:41 PM
  #35
mdstud's Avatar
mdstud
Well I've tried to test my injectors to see if they were firing with my DVM and I didn't get a reading so I'd say no. I think its just too quick of a pulse for it to pick up on.
Old Feb 7, 2005 | 04:01 PM
  #36
79Spitfire's Avatar
79Spitfire
your probably right. but thanks alot for trying, i really appreciate it mdstud. Although i have a volt/ohmmeter with a needle so maybe if i tried it with that i would be able to see the needle jump. I guess its worth a shot, im running out of options. I will post with results.
Old Feb 7, 2005 | 04:53 PM
  #37
chrono4's Avatar
chrono4
yes the hp will pull gas out of the tank its just hard on it as pumps are ment to push not pull. my 88 will run and drive just fine on just the hp until you really get on it the it kind of stutters. runs fine with both
Old Feb 7, 2005 | 05:56 PM
  #38
mdstud's Avatar
mdstud
Ya lemme know if that works, I may be investing in a needle volt/ohmmeter.
Old Feb 7, 2005 | 06:59 PM
  #39
79Spitfire's Avatar
79Spitfire
Well, I made a mistake on the fuel pressure. Apparently the fuel pressure guage isn't ready to use right out of the package. i guess you have to tighten the fittings more before using it, in the daylight today i noticed some bubbles around the fittings and after tightening them and testing all over i had nearly 40 pounds. I should have known better.
Old Feb 7, 2005 | 07:07 PM
  #40
mdstud's Avatar
mdstud
So we're back to the code 18, double check that connector at the TFI module. I would also take the module even though its new and have it tested.
Old Feb 7, 2005 | 07:08 PM
  #41
79Spitfire's Avatar
79Spitfire
The bad news is that it still wont start. I found a guy thats a certified ford mechanic with the dealers version of my cheap code scanner who says he'll be over tonight to hook it up and see what it says. With any luck he'll be able to pinpoint the problem better than i could with my cheapy scanner.
MDSTUD.......I havent tried to test the injectors with my meter yet but i will by the end of the day. I'll let you know what happens.
Old Feb 7, 2005 | 07:57 PM
  #42
Beast12's Avatar
Beast12
My truck has a code 18 and still runs. I don't know what difference it makes....but oh well...
-Matt
Old Feb 7, 2005 | 08:24 PM
  #43
mdstud's Avatar
mdstud
Beast have you cleared the codes?
Old Feb 7, 2005 | 08:59 PM
  #44
79Spitfire's Avatar
79Spitfire
ok.... heres the problem....low compression!!! All this time i thought my compression test guage was no good. If im lucky it'll just be the timing chain that jumped. ill check in later, i gotta go.
Old Feb 7, 2005 | 09:04 PM
  #45
Beast12's Avatar
Beast12
Yes. I have unhooked the battery for at least 30 mins and it still comes back..Weird!
-Matt
