Sponsored by: Auxito
Engine Swap
Old Feb 2, 2005 | 03:08 PM
Tblackboy's Avatar
Tblackboy
Engine Swap
What all has to be changed in swapping a 4.6 L engine with a 5.4 Liter in a 1998 F150? Or would it be easier to drop a 302 in it? I am tired of the pinging problem!
Old Feb 2, 2005 | 06:23 PM
LxMan1's Avatar
LxMan1
Have you cleaned the EGR ports? A clogged EGR system can cause pinging.
A 5.4 swap would be easier than the 302, but will still require a wiring harness change along with the PCM and exhaust system.
Old Feb 2, 2005 | 06:43 PM
cantrma's Avatar
cantrma
Run it hard enough long enough to be sure the carbon is burned and blown out. See if it still pings.
