S/d 5.4 Mileage Help ?
with less than 2500 ml's. we will be looking to increase hwy.mileage as this is a daily driver, any body with advice on this would be greatly appreciated. the truck is fine pulling as in that it has the 4:10 gr. set. members with bolt on suggestions can please give me any ideas they may have expeirenced for them selves, any person with expr. on the chip or command mod. set up, is the two wire inexpensive useful as to the highly expensive units ? throttle body ideas, i'm under the assumption that a swirl at the plenum would be more effeicent than out at the mass meter ? we are currently in the process of dumping the 12 plus lb. fan assymbely an running an electric system... thank you for both F.T.E. and it's reader for this forum to both learn an educate --------
