Pollution Pump
Old May 2, 2002 | 07:03 PM
seymour's Avatar
seymour
Pollution Pump
1981 F-100, 302 2 barrel with 60 000 kms.
Recently removed the belt which drives the pollution pump because the pump was making a rattling noise. Since I done this, the engine seems to be producing a exceptional amount of pressure in the base.
Can some one tell me if the pollution pump aids in the removal of crank case pressure along with the PCV. Or am I way of track.
Thanks in advance.
Old May 2, 2002 | 09:36 PM
Franklin2's Avatar
Franklin2
Pollution Pump
The smog pump doesn't have anything to do with the PCV system that I know of. I guess you are saying you are getting too much pressure in the crankcase? I guess you checked the pcv system to see if it was working? Engines with alot of miles will have some blowby past the piston rings and cause this.
Old May 4, 2002 | 02:42 PM
Greywolf's Avatar
Greywolf
Pollution Pump
I strongly recommend capping off the outlet hose on the back of the pump if you do this (pull the belt). The reason is - the check valves sometimes fail and exhaust gas will corrode the insides of the pump. That can make it totally useless later on if you ever have to have it running again.
I've seen a few locked up tighter than fort Knox...
Old May 4, 2002 | 05:03 PM
Gary_TN's Avatar
Gary_TN
Pollution Pump
wicat3
Jul 6, 2012 06:54 AM
kyflaresideon20s
Oct 12, 2011 10:54 AM
frankyford
Aug 20, 2006 06:27 AM
blueovalwonder
Jan 10, 2005 09:06 AM
