Cracked flathead, any help?
Old Feb 2, 2005 | 08:45 AM
Scott123's Avatar
Scott123
Back before starting a complete restoration my F1 steamed a little out the passenger side tailpipe until the engine got hot, then would quit and ran fine the whole time. Pulled the head off last night and the #3 cylinder has a crack running from about 3/4 inch down in the cylinder, up and to the exhaust seat. It runs to the hardened seat so not sure how far in there it goes yet as I haven't taken the valve out. Does anyone know of anyone in the Missouri area that can fix such a crack? The local engine shop says they can but I'm looking for anyone with experience first. I know I should find another block, but just in case I can't find one I will have to salvage this one.
Scott
Old Feb 2, 2005 | 10:14 AM
ALBUQ F-1's Avatar
ALBUQ F-1
You'll need a sleeve for starters, and flatties are sleeved a little differently than more modern engines. That's a pretty significant crack. To be honest, unless you have a lot of money into the block, you might start shopping for a good used one. It is likely to be cheaper.
-- Ross
Old Feb 2, 2005 | 08:34 PM
oscarxyz's Avatar
oscarxyz
Scott, sorry to hear about your engine woes.
Good luck in your search.
Shawn 82
Sep 2, 2014 08:12 AM
tobermans
All Things Towing
Jan 16, 2007 09:51 PM
fixingbus
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 24, 2005 01:44 AM
Saguaro_7.3
Dec 28, 2004 12:22 PM
Palmer
18
Aug 26, 2004 03:31 PM
