Oil & Lubrication
seafoam
Old Feb 1, 2005 | 10:46 PM
99stocksport's Avatar
99stocksport
seafoam
have any of yall heard of or used Seafoam...if so how did work...did you improved performance
thanks
Davis
Old Feb 2, 2005 | 12:30 AM
76390FE's Avatar
76390FE
I have used it for many purposes, it didn't really "improve performance". I use it as a stabilizer, and carb cleaner. Seems to be one of the best products out there.
Old Feb 2, 2005 | 01:19 AM
Monty06's Avatar
Monty06
i use it for fuel injector cleaner and to clean my gas tank. i also use it in my oil works wonders now with gains i don't see any just helps clean alot of gunk out.
Old Feb 2, 2005 | 03:23 PM
csramsey640's Avatar
csramsey640
you have to know how to use it. Seafoam can be very beneficial, if its even needed. For carbon deposits on say pistons, it can work well by injesting straight through while revving the engine. I havent seen huge results when adding to the tank
Old Feb 2, 2005 | 03:59 PM
Golfmore's Avatar
Golfmore
For a carbon eliminator, water works just as good, and has for may years. I have used 2 liters of water once a year, and have no carbon build up. (Yup, those cyls are clean.)
Old Feb 3, 2005 | 08:08 AM
DOHC's Avatar
DOHC
Here's a two page thread about it
https://www.ford-trucks.com/forums/s...hlight=seafoam
Mikeymoe
Feb 26, 2012 06:30 PM
mblayton
1978 - 1996 Big Bronco
Oct 7, 2011 11:08 PM
1OldFordMan
13
Oct 27, 2009 02:39 PM
DAI532
Sep 1, 2009 10:04 AM
basstardo
General Automotive Discussion
Jan 18, 2007 09:45 AM
