1978 - 1996 Big Bronco
4-barrel intake gasket
Old Feb 1, 2005 | 09:50 PM
66lane's Avatar
66lane
Question 4-barrel intake gasket
I was wondering if a gasket for a stock 2 barrel intake will work with a Edelbrock 4 barrel intake? I changed my mind mid stream, and decided to go with the 4 barrel, but have already purchased a complete gasket kit for the stock engine. I don't have a new gasket for the 4 barrel since I bought it used off of ebay.
Old Feb 1, 2005 | 10:06 PM
sacf250's Avatar
sacf250
you will need to get an adapter plate to use the 4 barrel on the two barrel intake. my brother did the same thing and his runs good unless you really floor it and then it stumbles a little and then kicks in.
Old Feb 1, 2005 | 10:30 PM
f1001978's Avatar
f1001978
I assume this is a 351m you are working on, if so the stock manifold gaskets will be fine. The 351c had either 2v or 4v heads and intakes which were completely different but the 351m only came with 2v heads.
Old Feb 2, 2005 | 10:08 PM
66lane's Avatar
66lane
Wink
yes it is a 351 m. Thanks for the info.
