Odometer Code Reading 97 F250 5.8L
Old Feb 1, 2005 | 06:19 PM
Nitramjr's Avatar
Nitramjr
I recently read on here about getting codes by holding the "select" button on the odometer and turning on the key. I tried it on my truck and got the following:
E 08 6
Any ideas what this means? I can't find the original post and search won't let me in tonight.
I know this forum only goes through 1996 but the '97 HD F250 is more like the '96 than anything else and I couldn't find a forum for my truck.
Thanks.
Old Feb 2, 2005 | 07:39 AM
Nitramjr's Avatar
Nitramjr
bump to top
Old Feb 2, 2005 | 01:30 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Bump to the top.
Old Feb 2, 2005 | 02:36 PM
96f-150's Avatar
96f-150
The "E" stands for english. The number after that is the microprocessor revision level but i don't know what that means sorry. The function you were performing is not used as a diagnostic procedure but instead is used to calibrate your speedo for different tire sizes. If im all washed up someone will correct me soon. If you go to the tech articles section of this site it shows you step by step how to calibrate it.
Old Feb 2, 2005 | 03:01 PM
Nitramjr's Avatar
Nitramjr
Great. Thanks or the info. I read somewhere that diagnostic codes could be acquired this way. Thanks for setting that straight.
CollinsCD
Dec 3, 2013 06:35 AM
chaser1602
1997 - 2003 F150
May 13, 2013 08:37 PM
Brian Lawrence
1997 - 2003 F150
Sep 14, 2007 10:48 AM
97FireCommand
Feb 27, 2005 01:37 PM
C_Marshall
Oct 3, 2001 07:12 PM
