Temperature gage problem
Old Feb 1, 2005 | 05:24 PM
bardeenm1's Avatar
bardeenm1
I have a 98 2.5l ford ranger my temperature gage goes all the way to hot as soon as I start the truck some times after driving for a few the gage will drop down to where it should be. I know the truck isn't hot or overheating my fluid level is full and not leaking. The hoses get warm and seem to be circulating. The heat works great and I'm sure I'm not overheating! I was thinking it could be something to do with a sensor and am looking for suggestions. Thanks Marc
Old Feb 1, 2005 | 05:34 PM
rangerford's Avatar
rangerford
Maybe it is your Coolant Temp Sensor (CTS)?
Old Feb 1, 2005 | 05:58 PM
byo71's Avatar
byo71
its mounted by the thermoststat.
Old Feb 1, 2005 | 06:06 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE..
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..
See you on the boards.
Old Feb 2, 2005 | 12:46 PM
wphun's Avatar
wphun
Just replaced mine on a 94 2.3. It was doing the same thing.
My cts was located on the rt. side of the engine (while looking at it) in the block. Down low.
I gave the guy at jiffy lube a 20 to rplace it. He got kinda burned by coolant.
Mdc9966
Dec 6, 2016 10:22 AM
Vista703
Aug 26, 2015 02:10 PM
RUNVS
All Things Towing
Jan 15, 2010 01:36 PM
riverbottom
1997 - 2003 F150
Aug 20, 2009 09:25 PM
mtmcalli
Bronco II
Feb 17, 2006 11:02 AM
