Best mpg from inline 6?
Old Aug 13, 2012 | 12:16 AM
  #106
SideWinder4.9l's Avatar
SideWinder4.9l
Topped off tonight...Checked mpg..
18.11 mixed/rural...And not even starting to break a sweat....
Old Aug 13, 2012 | 01:01 AM
  #107
Thudpucker's Avatar
Thudpucker
As I recall there is a Special Rod for Cast Steel.
We heated the whole Exhaust Manifold on a Camp Fire before welding.
Your right about Brazing, but it holds for quite a while though!
Old Aug 13, 2012 | 02:56 PM
  #108
SideWinder4.9l
Topped off today after returning from class...18.95 mixed/city/rural (If you've been to eastern Ky, you'll know what I mean)...A/C on also...
But this was a lot of "Highway" miles too....so yea...
Even at that though, there's not much flat ground around here...
Old Aug 13, 2012 | 03:41 PM
  #109
Thudpucker's Avatar
Thudpucker
I took a trip up north to Indiana. Went up the east side of Kentucky and came back down the west side.
Sure enough. There aint no flat hills in that state at all.
Here in Alabama, they put a sharp curve at the top and bottom of every hill so your always on the brakes or the Gas.
This is a Gas mileage state too!
Old Aug 13, 2012 | 05:09 PM
  #110
SideWinder4.9l
I'm guessing you either went through Salyersville (Where I live) or Pikeville...?
What roads did you take? Rt. 23 North?
Old Aug 14, 2012 | 07:47 PM
  #111
willowbilly3's Avatar
willowbilly3
I don't preheat, not saying it's wrong. What I use is the cheap cast iron arc rod, not the nickel stuff. V the crack out good. Weld about 1/2", then peen the crap out of it with the pointy end of the chipping hammer, until you can almost touch the metal, repeat until finished. The peening relieves the stress. When you are done welding. grind the weld and dress it with a flap wheel. If there is any undercut beside the weld it has to be welded up because that's a fracture line. I have 100% success rate with this process.
Old Jan 3, 2013 | 07:31 PM
  #112
Duche400's Avatar
Duche400
My '92 300 3.08 5spd. Got 17.9 hyw at its best. That was 60 mph. My '70 300 4x4 got 13. Man, I get 15 with my 352!
Old Jan 18, 2016 | 02:25 AM
  #113
straightsixfury's Avatar
straightsixfury
Mine gets about 22 in the wind on hilly highways. Probably 25 in optimal driving conditions on level ground.
Old Dec 31, 2018 | 12:44 PM
  #114
A pause for the COZ's Avatar
A pause for the COZ
No way i could ever say I get good mileage from ether of my 4.9's
last time I actually checked. i was getting a little over 10 mpg on my F250 2wd.
My F150 4.9 4wd. Might get the same. But I have been afraid to actually check it.
I decided to just be happy in knowing. What I have in them, how absolutely reliable and useful they are.
Neither one owes me a dime.
I can buy a lot of gas before I even get worried.
websurfer
19
Feb 21, 2024 06:19 PM
ernesteugene
Oct 28, 2017 12:48 PM
06FUN
Oct 29, 2016 07:53 AM
FuzzFace2
15
May 21, 2016 09:53 PM
rstpe
Mar 2, 2016 07:05 PM
