Best mpg from inline 6?
Old Feb 4, 2005 | 03:29 PM
calazo's Avatar
calazo
Unhappy 300 Mileage...
I agree, it's very hard to tell since the 300 MPG range is quite wide. I don't think I'll have the best MPG figures for you but maybe the worst in the forum: 8MPG for a 2WD Bronco, 3.08 gears, C-6, 1-bbl carb all stock & 235-75-15 tires (and at an altitude of 8.000ft). A lot of fellas with V-8s and more cubes get better mileage! ; that's gotta suck!
Old Feb 4, 2005 | 04:04 PM
Broncocustom1219's Avatar
Broncocustom1219
I get 17 on a good day. I have 3" gibson cat back with a high flow cat, tb spacer, K&N and a just new tune up i always run part synthetic and a quart of lucas oil stabilizer. I have a bug deflector and a moon visor as well. I also have 33's on my truck. At 65mph im at about 2000rpm Wickymustang, you are doing great on mileage. what exactly are you doing? Let us all in the secret!!
Old Feb 4, 2005 | 05:20 PM
Silver Streak's Avatar
Silver Streak
I got 19.6 one time on the way back from Texas with a 30 mph tail wind. I usually average about 15-16 mpg on a tank. I'm guessing 13 city and about 17 highway. Doesn't seem to matter if I drive like an old lady or like I stole it. The latter is usually the case.
Old Feb 4, 2005 | 05:32 PM
Project Lazarus's Avatar
Project Lazarus
Originally Posted by Red2003XLT
You guys that are getting less than stellar mileage. What is your cruising rpm?
I'm doing 2500 rpm's at about 60 mph.
Old Feb 4, 2005 | 06:04 PM
wickymustang's Avatar
wickymustang
I'm runningright around 2K at 65 or so mph. Like I said before, I take it easy on the skinny pedal, maintian the engine, and drive how I was taught. You can't always just leave it in a certain gear and have that be that. My dad drove 18 wheelers long haul for a long time, now he drives dumpers for the local landscaping and excavation company. He taught me all the intracacies of the manual tranny. This is still with the original O2 sensor and fuel filter. They are getting changed over spring break and then the MPG will hopefully go up a little more.
Old Feb 4, 2005 | 09:52 PM
broncr's Avatar
broncr
I've always gotten about 14 on Winter gas, & a bit over 15 on the "good" stuff. My miles are always mixed city & hiway. 'Just swapped in a BW T-19 (synchro 1st, & close ratio/diesel gearset), which seems to have given me a .5mpg "bump". Apparently "decent" for an old 4X4 Bronco...
I've got a gearsplitter OD on the way , which I hope/expect will get me into the 17-19 range. Even if it doesn't, I'll have "four on the floor", & four more on the "tree" .
Old Feb 4, 2005 | 10:57 PM
sierraben's Avatar
sierraben
broncr, what kind of gear splitter/OD are you getting?
Old Feb 5, 2005 | 07:52 AM
Red2003XLT's Avatar
Red2003XLT
Thanks, I've been wondering where is the sweet spot.
Old Feb 5, 2005 | 09:45 AM
Broncocustom1219
I have the e4od with over drive. I was doing some highway driving today and at 65mph with 33" x 12.5 i run at 1850.
Old Feb 5, 2005 | 09:56 AM
Sgt Wonderful's Avatar
Sgt Wonderful
broncr, what is a gearsplitter OD
Old Feb 5, 2005 | 11:57 AM
broncr's Avatar
broncr
I'm going with the Rolls - the Gear Vendors gear unit. It is essentially an electronic two speed overdrive, that bolts behind the tranny or (in my case) transfer case. They make them for ANY application (auto, manual, RV, racing, etc). The base unit is the same, with an adaptor plate for each specific application.You get overdrive in every gear, with the flip of a shifter-mounted switch. Needless to say, the ARE pricey.
It doesn't work in 4X4, but I don't need splitting/OD there anyway. I've got a hi/low T-case for that.
My old T-18 was geared: 6.39 - 1st(granny), 3.09 - 2nd, 1.69 - 3rd, & 1.0 - 4th. Pretty much a "three speed".
The close ratio T-19 gives a SYNCHRO'd, 4.02 1st (MUCH taller, 15-20 mph top, instead of 3-5mph), 2.41 - 2nd (slightly taller), 1.41 - 3rd (sl. taller), and 1.0 - 4th ( same). More like a car tranny, but TOUGH - mine came out of an '88 F250 V-8 Diesel.
The NICE thing is, A (FORD) T-19 is a STRAIGHT SWAP for the T-18. (EXACTLY). BEWARE! There ARE non-Ford T-19's! (Scout, Jeep(?) )
With the T-19 & GV OD/splitter, there is an OD in each gear, in effect giving 2 gears between the T-18's 2nd & 3rd, 2 between the T-18's 3rd & 4th, the same 4th, plus a final OD.
1st-OD probably won't get used much (nor 2nd, OD), but it's there.
Old Feb 5, 2005 | 02:01 PM
feeniks4.9's Avatar
feeniks4.9
Red face
Excellent advice, really. I was taught to visualize an egg between your foot and the pedal - I'm sometimes crushing that egg, I admit, but I do notice the difference. Learn to use your clutch correctly: find the sweet spot (it's hard to do, but once you realize it's there, it will change everything for you). Watch little things like tire pressure, oil change intervals/proper oil weight, air filters, not running your AC or heat unless necessary, keeping your windows rolled up (also unless necessary... You know, if you had Taco Bell for lunch... ). I have a molded shell, which helps with the phantom wind drag, and I'm just happy if I can fill both tanks and make it from paycheck to paycheck every two weeks.
Old Feb 5, 2005 | 03:22 PM
  #28
fordtruckin's Avatar
fordtruckin
With my truck the best I've gotten is right at 20 mpg on the freeway only. It's a 1995 with the auto, 32" BFG Commercials and 3.55's. That was with an open bed however, now I have a shell and I haven't measured with it. Pics are in my gallery
Old Feb 6, 2005 | 09:30 PM
  #29
f15terwitha6ter's Avatar
f15terwitha6ter
I would get about 13 in my old truck 300 4 speed 1 bbl though.
Old Feb 7, 2005 | 09:31 PM
  #30
74crwcb429hibPS4spd's Avatar
74crwcb429hibPS4spd
11 to 15 MPG in a 460 why not better MPG in a I6
I don't get it? How come a 300 I6 doesn't get like 22 or 23 MPG?
