Sponsored by: Auxito
check engine light "codes"
Old Feb 1, 2005 | 01:25 PM
gui88ford's Avatar
gui88ford
Question check engine light "codes"
i just took my truck to auto zone.....they put their computer on the truck and it came back with one code.....
P0401 is the code
what is it?
what do i have to do to fix it?
thanks
truck is an 01 F-150 4.6 L 5spd 4x4 with 49,000 miles
Old Feb 1, 2005 | 02:03 PM
screwy's Avatar
screwy
P0401 - EGR Flow Insufficient Detected
Old Feb 1, 2005 | 02:16 PM
gui88ford's Avatar
gui88ford
ok, so what should i do to try to fix it
anyone help me out please
Old Feb 1, 2005 | 02:32 PM
MBDiagMan's Avatar
MBDiagMan
Clean your EGR valve and passages and that will probably take care of it.
Good luck,
Doc
Old Feb 1, 2005 | 02:59 PM
gui88ford's Avatar
gui88ford
what is this DPFE....sensor i'm reading about....where is that located on my truck....i can't find it.....thanks
Old Feb 1, 2005 | 11:00 PM
Racerguy's Avatar
Racerguy
There is a pipe running up from the driver's side exhaust manifold to the EGR valve. Coming off that are 2 small hoses. At the top of those hoses is the DPFE sensor. It has the 2 hoses and 1 electrical connector on it.
Old Feb 2, 2005 | 08:02 AM
gui88ford's Avatar
gui88ford
thanks.....i'm going to replace that....now what if that doesn't solve my problem....what are my next steps....i read something about using a shop vac on the egr valve....i can't find the post again but i was curious wht they were talking about
Old Feb 2, 2005 | 08:33 AM
mathelm's Avatar
mathelm
https://www.ford-trucks.com/forums/s...d.php?t=248921
