Identifying this Engine
Enough butt kissing :-) Well here is my problem..
I have the truck now and have put in a new Water Cooler, (Radiator in SA) and a new Starter and Four new tyres...., The truck now runs.... although roughly.... (it was standing for more than 3 Years since it last ran...)
I want to do a service on the Engine (Motor in SA) but I need specs, I baught a Service Manual but the Manual does not explain hot to identify what Engine the truck has (it is not the original Engine) It is a V8, The Previous Owner says it is a 5L Ranchero Engine, but I need to know where to look to see what Engine it is.
I will be doing a complete rebuild and will post my progress along the way - It will take a while, Money it tight and Body work is Costly here. Also parts might pose a problem but I also have a Pontiac Transport SE 3.8 and I know how to look for hard to find parts......
I would just like to mention that the forum seems very helpful and knowlegable and I have allready seen many posts that will assist me as time goes by.....
Thanks in Anticipation....
Last edited by Mil1ion; Feb 1, 2005 at 02:50 PM. Reason: Re-titled to best reflect the actual TOPIC
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
Please read this:
It is attached to the top of this forum as a Read First
https://www.ford-trucks.com/forums/s...d.php?t=102632
Write down ALL of the casting numbers on the block,heads,Intake & Exhaust manifolds & then post them to this threads.
We'll do the rest
