Frustrated finding van I want
This image from autosite shows what I want well.
Anyone know how to get what I want, what I really really want?
Think cutom interior.
Ford Commercial trucks
Or ask your dealer about a "Crew Van Package" which may be even closer:
Crew Van Package
- 2nd row vinyl bench seat
- Metal bulkhead
- Low series rear partial headliner
- Full “B” pillar trim panels
- Low series side and back door trim panels
Would I have to go to a different dealer for a fleet van or how would i go about picking one up? I'm also inclined to think a used van might be best for starters.
Remove the extra seats for the cargo room and you have the benefit of a much more effective heat and air conditioning system and the floor mat.
I'm not sure why you don't want the rear quarter windows, if it's just a styling issue or a functional one. If you elaborate on that a little bit, maybe a solution can be found.
Gene
I wouldn't completely rule out having rear windows, but I much prefer their absence, and yes styling is part of it. I pretty much want a two compartment vehicle. Church vans are a possibility, but chances are they'd be pretty worn if they're getting rid of them.
I can relate to the frustration as I looked for something similiar myself for a long time. Not to be found. The other posts are right on about having to deal with trade offs and what is important to you. It depends on how much you want in creature comforts.
A 15 pass (Extended Van) comes with all the seats and allows you to reconfigure to your hearts content by moving the seat mounts to where ever you want them (pretty much) plus you have seat belts already properly tied in to strong points.
With the XLT you get the rear heat/A/C which makes a huge difference in heating and cooling the cave inside. You get all the trim panels and headliner which you could modify with a little thought to butt up to the cabinets lining the rear. (Not the headliner as it carries the overhead vents and lighting.
If you are set on the fleetside look for the rear sides, and rear quarters, those windows come out without a lot of effort and you could make a metal or fiberglass insert which would bolt in place of the windows. A body shop would easily fill the seams /gaps and you would have what you want. The windows for the side doors and behind the driver would be stock installed flush mounted. With the number of vans built I am sure you could find rear doors without windows if you wanted those as well.
E350 vs E250 - For an extended van and 4x4 conversion (if that is what I read in your post) I would and did choose E350. These are big heavy units already and to have the additional capacities and upgrades that come with the 350 chassis just seemed smart to me.
If creture comfort is not important, then a Windowless Extended E350 Cargo would be the way to go and just add aftermarket windows to the doors and behind driver. You may be able to order the RV chassis with a full headliner and the creture comforts, but it will not come with rear seats or rear seat belts. Again, you should be able find these in a wrecking yard or Ebay.
We went with a used 2003 15 pass E350 V10 w 24k miles. Bought on Ebay for less than $17k over a year ago. Did a Quadvan 4x4 conversion, sports suspension and then I reconfigured seating so we have flexible storage in the back or the entire van for camping. I am going to make color matched fabric covered panels I will insert inside the rear quarter and rear door windows to block out the rear of the van for privacy when we are camping and use curtains on the windows behind the driver and side doors and across the front window to complete the privacy. From the outsinde it will look like a normal full window van but inside I will have the cargo feeling for sleeping and camping.
Just some thoughts on the subject..... Good Luck!
Check your state laws for EPA testing, many times the 1 ton will be not subject to so many rules and regs. Plus, the cost difference is very minor, the ride quality is the same but you have more tow and cargo hauling capacity. A used 1 ton ext length can be bot cheap, add a couple windows, and a power folding rear seat that makes into a sleeper, some cabinets and a partition and you're set. But unless you get a passenger van you'll have no rear a/c & heat. And that is a big space to overcome with a front only heat/a-c unit.
The raised roof option is about $1500 locally, my last van had it, I wish this van had it, but I do notice less wind resistance in gusty, side wind conditions.
Be sure you weigh the difference in diesel costs, both higher price initially and much higher fuel and maintenance costs as opposed to a gas engine. Alot of towing heavy loads and alot of miles must be traveled to come out even, just something to think about. The 5.4 V8 and the 6.8 V-10 get very similar mileage, but the power difference is huge.
And finally, Quigley will normally only do 1 year old or less vehicles, so check with them if you want 4WD. A good positrac unit will double the traction for most places, at only $500/$600 or so installed. Most all the trucks that pre-run the big off-road desert races are 2WD with rear lockers, FYI, Ken
There are many of the "church style" vans available for sale at just about any wear level you are willing to pay for. You can check locally to see what may be available. Some organizations are selling their vans earlier than they might normally due to the bad publicity of the roll over scare.
There is a company in North Carolina ( adventurevans.com ) that is in the van leasing and rental business that sells their used vans on ebay. Most are one to two years old and appear to be in very good condition. I'm not endorsing them, just giving you a place to look.
I'm not sure if the van will be used for business or personal transportation or both, but to address some of the issues you mentioned:
The rear quarter glass has a fairly dark tint on it from the factory so if you painted the backside of the shelving units flat black I doubt that they would be very noticeable from the outside.
If the van is for commercial purposes you could use the rear windows as a place to put your company signs. Also, there are companies that make custom vinyl signs or graphics that cover both sheet metal and window glass with one large logo. You cannot see into the vehicle but you can see out of the windows as if it were not there. Very cool. I saw that on either a Prevost or MCI motor coach website if you are interested in checking in to it. Or the filler panels could be fabricated as mentioned by another poster. You could do a lot to the van for the money you will save buying a used van of this type.
Ken's remarks about the heat and air are what I was getting at earlier. Your middle seat passengers will be very uncomfortable with only the dash air and it will be hard to cool the van in the driver's area on a very hot day without the rear air. If you intend to build a solid bulkhead to divide the back from the front, you would probably have to engineer an air return duct (the intake) that takes some of it's air from the front and some from the rear. In my opinion it wouldn't be hard to do and would be well worth the effort.
If you shop around for a while you will see some of the 15 passenger vans in XLT trim and with V10 engines. That would be my choice.
Gene
the heat and air are what I was getting at earlier. Your middle seat passengers will be very uncomfortable with only the dash air and it will be hard to cool the van in the driver's area on a very hot day without the rear air. If you intend to build a solid bulkhead to divide the back from the front, you would probably have to engineer an air return duct (the intake) that takes some of it's air from the front and some from the rear. Gene
