Changing From 2 to 4 Barrell
Old May 14, 2002 | 05:49 PM
1965_ford_mustang's Avatar
1965_ford_mustang
Post Changing From 2 to 4 Barrell
I have an 84' f-150 with a 302. It currently has the original 2 barrell carb and intake on it. I want to change it to a 4 barrell. I would like to use an edelbrock performer intake with a holley carb. Can I do this without failing emissions testing? I'm in Tennessee.
Old May 16, 2002 | 09:27 AM
Franklin2's Avatar
Franklin2
Check and see if your distributor has a vacuum advance. If no, you might have to change it to a duraspark II. If it has the can with the vacuum line going to it, you should be ok. If you get a holley or an edelbrock, both manufacturers have emission carbs and non-emission carbs. The non-emission carbs are tuned with richer jetting, and may be borderline for passing emissions. If they have a underhood visual inspection, it may not pass anyway, but maybe you could hide the carb under the original aircleaner. I would keep the aircleaner and the hook-up to the exhaust manifold pipe anyway for wintertime driving.
Old May 16, 2002 | 09:30 AM
Franklin2's Avatar
Franklin2
80 f-150
Sep 5, 2011 11:47 PM
Lumpy78
May 4, 2010 11:25 PM
2002BLGT
Nov 12, 2005 02:15 PM
83f100ss
Jan 19, 2004 12:22 AM
1965_ford_mustang
May 15, 2002 08:54 PM
