Bronco II Ford Bronco II
General BII tech questions
Old Jan 31, 2005 | 11:02 PM
88gt's Avatar
88gt
Hi Guys,
I have a 4 wheel drive, 2.9L 1989 Bronco II.
I'd like to replace the factory 190k+ shocks. The car is a daily driver, so I don't want anything too pricey. I'm thinking about getting some cheap Kragen/Autozone replacement shocks. Is there anything I should look to avoid, or look to find here? Are there better similar priced alternatives?
I saw the article on here about cleaing carbon buildup by spraying PM-3 fluid in the throttle body. Can I do this with my engine also, or is there something else I should try. I've tried adding higher octane, but it hasn't worked.
Also, I hear some sort of rattling when I release the clutch, or when I'm accelerating at very low RPM ranges in first gear. It sounds like it's coming from below my feet, but I can't really tell. Any ideas what this may be?
Thanks in advance, guys.
Old Jan 31, 2005 | 11:52 PM
Monty06's Avatar
Monty06
you can clean your tb with a number of things i have used wd-40,carb cleaner,seafoam cleaner they all remove carbon. now your other q's i can't answer sorry . Monty
Old Feb 1, 2005 | 12:09 AM
88gt's Avatar
88gt
To clarify, I think I'm experiencing detonation, and it may be a result of engine carbon build-up. I'm pretty sure my throttle body is fine.
Old Feb 1, 2005 | 12:24 AM
Monty06's Avatar
Monty06
then i would use some seafoam to take off the carbon built up from the inside .
Old Feb 1, 2005 | 07:10 PM
Ken00's Avatar
Ken00
When you do your shocks make sure you spary the bolts good with PB, etc, the front stud type break off very easily.
Have you checked your timing for the spark knock problem.
