Sponsored by: Auxito
Outside temperature gauge
Old Jan 31, 2005 | 03:20 PM
WHITESTANG95's Avatar
WHITESTANG95
I have a 2002 F150 pickup, the outside temp. gauge
starts out reading the outside temp. around 10 degrees high.
After driving a while it jumps to readings of 50 to 60 degrees
higher then the outside temp.. Any ideas what the problem is
and how to fix it???
Old Jan 31, 2005 | 07:14 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy
Old Jan 31, 2005 | 09:54 PM
triton_2002's Avatar
triton_2002
Alot of people seem to be having trouble with their temp sensors lately. I wonder if its the cold or just coincidence? Luckily the low temp here is in the mid 40's, but should be back in the 80's in a few days!
Take a look here for some help:
http://www.fordtrucks.com/forums/sho...d.php?t=337909
Old Feb 3, 2005 | 08:46 AM
WHITESTANG95
Thanks for the help.
