Sponsored by: Kumho
Adjusting camber on I-beams
Old Jan 31, 2005 | 12:37 PM
beertestr's Avatar
beertestr
I was looking at the Autofab lift kit, and sorry, I am not paying $750 for two springs and a pair of re-bent i-beams. Who in S.E. Michigan can tweak i-beams for camber and caster? I am thinking of lifting my 65 F100, and I can find taller stiffer springs to lift the front end for cheap, but I need to get the camber and caster back in line. If autofab can do it, I assume they are either bending them in a stupid big press, or are heating them and tweaking them..
I guess the better Q is to ask how you actually align an I-beam setup if you need more than toe adjustments??
Old Jan 31, 2005 | 06:28 PM
SRD4X4's Avatar
SRD4X4
The I-Beams have to bent to correct camber,on averge 1" lift will add 1 deg. of possitive camber.Some shops won't bend more than 1-1 1/2 deg.,some will go more.Unless you drop the radius arm brackets down the same amount as the lift,the caster is going to go negative.
Old Jan 31, 2005 | 06:34 PM
beertestr's Avatar
beertestr
Sounds like I might make me some drop brackets. I just was wondering how the autofab kits get realigned. They do it all by maintaining the original mounts, and tweaking the i-beams, apparently tweaking the heck out of them..
Do the arms get heated and bent, or just a big 'ol press? I wonder if it makes more sense to just make new i-beams.
1966f250
Nov 18, 2015 01:01 PM
johnve
Washington Chapter
Aug 12, 2007 09:37 AM
SRT77
Apr 5, 2007 08:27 AM
llehmn
Oct 6, 2005 07:54 PM
