tire size
Old Feb 22, 2005 | 04:22 PM
billsdaddy's Avatar
billsdaddy
http://www.summitracing.com/catalogs...nfeb/327f.html
Someone gave me this link. It was exactly what I'd been looking for! Good luck, RC
Old Feb 22, 2005 | 07:17 PM
85F_150driver's Avatar
85F_150driver
summitracing.com has them cheap in both 15s and 16s. just make sure you get the right backspacing and bolt pattern.
Old Feb 22, 2005 | 07:55 PM
datchew's Avatar
datchew
outta luck
guess i'm outta luck.
the biggest they show on most of those sites is a 15" wheel for the 5-lug pattern (what i have).
after that, you have to have the 6 bolt pattern.
thanks much guys.
Old Feb 22, 2005 | 08:17 PM
MontanaFord's Avatar
MontanaFord
datchew...check with your local tire store...they should be able to order whatever rims you want in just about whatever size...i found i can get 5 lug 16" tires at one of the stores here for about 300 bucks for a set....add 75 for the spare rim....
also...Red made a really really good point on the safety issue....i have a son that will be 3 in may, and i wouldn't do anything to my truck that could possibly jeapardize his well-being and safety...
Originally Posted by Ole Red 4x4
Well, good luck......oh and here's another opinion.....stay away from those cheap block lifts!!! Kinda like throwin good money after bad. I plan on lifting mine soon too and I am gonna have to do a suspension lift.....I have an 18 mo son Brant Alban, first kid, and I ain't gotta tell you , he's my pride and joy. I guess I look at it as a matter of safety....and those lifts aren't always that!!
MontanaFord
Old Feb 22, 2005 | 10:23 PM
f100beatertruck's Avatar
f100beatertruck
I've had both 32x11.50's and 31x10.50's on my 86. For the street, the 32's are fine, for the trail I'd stay with 31's. I've seen these trucks with 35's with the stock suspension.
With larger tires then 31's you'll hit the body from time to time on the front. If the body is rusty you could sawzall the wheelwells and run bigger tires.
David
Old Feb 23, 2005 | 10:17 AM
F150stepside's Avatar
F150stepside
here is a link to a convertor for metric to standard a 235/75/15 is a 28.9-75/15 tire I had 33's on my 86 f150 2wd would rub on lock to lock turns also you have to watch rim with if only using standard rims. rember that Dodge rims (older) are same bolt pattern as Ford check local junk yards for 4X4 doges they had a nice alum rim that was I believe 7 or 8 inches wide. can get them cheap as low demand. type in metric tire to inches in google and it will give listing for
4lo calculator and can use that to figure out size.
Old Feb 23, 2005 | 01:18 PM
datchew's Avatar
datchew
thanks guys.
i'm not looking for off-road tires or anything like that.
i've got access to some on/off basically "dirt-road and pavement only" tires that are 16" but my stock rims are 15"
MontanaFord ... i did check with the local stores and they all said that the wagon wheel 5 lug only go up to 15".
Summitracing(dot)com (i can't write links... junior member you know) shows 5 lug only up to 15" as well.
Guess i'll keep digging or just buy new tires to go on my stock rims.
Old Feb 23, 2005 | 04:12 PM
f100beatertruck
Wheel Vintiques has 16x7 and 16x8 white wheels with 4 inch back spacing and a 5 on 5 1/2 bolt circle. They list for $72 and $81 (Jobber) each and the P/N's are 82-675504 for the 16x7 and 82-685504 for the 16x8. They're also available in chrome, and summit lists the chrome ones, so I'm sure you could order the white ones.
These have round holes, they're not wagon wheels, but they could be close enough for you...
You can also try stockton wheel. I know they make all kinds of different wheels.
Look at the numbers both ways, it may be cheaper to sell the 16's and buy some 15" tires....
David
Old Feb 23, 2005 | 09:01 PM
F150stepside
try the junk yards Dodge truck in the 90's came with 16 x7 rims 5x51/2 bolt pattern should be able to find them easy and cheap as there is a low demand for them. can get aftermarket wheels also. look for 1997 or 98 Ram 1500 as came with the 16x7 wheels
jac43k
15
Mar 17, 2024 07:15 PM
Kestrel116
1947 and Older Ford Trucks
20
Jul 31, 2021 08:00 PM
madpogue
Jul 8, 2017 07:22 PM
SC78f150
Jan 15, 2014 07:56 PM
rebocardo
Oct 7, 2002 02:13 AM
