General Automotive Discussion
Dodge front end clicking
Old Jan 30, 2005 | 09:26 PM
mike L's Avatar
mike L
I have a 1994 dodge caravan. I hear a click, click on the left front end when i do a right hand turn on the road. Its only done it once a week, three times now. I heard a click, click once to on the right side to while doing a left turn. I just had the struts replaced and a front end alignment. Van runs straight, no tire wear. I'm think front wheel bearings what do you think.Van has 150,000 miles and a new transmission. Front brake shoes look ok to.
Thanks,
Mike
Old Jan 30, 2005 | 09:33 PM
muscletruck7379's Avatar
muscletruck7379
constant velocity joints, around 100 bucks to fix, and not that hard either (i did my first in a little over an hour)
Old Jan 31, 2005 | 06:19 AM
Beast12's Avatar
Beast12
I agree with Muscletruck. It is your CV joints. Good luck!
-Matt
Old Jan 31, 2005 | 09:11 AM
mike L's Avatar
mike L
CV joints
Thanks guys! I'll have the garage do it, its to cold out. Is checking CV joints part of doing a front end alignment? I was wondering if they missed it when doing the front end alignment last month. How do you check the CV joints when the van is on the lift? Can I get them to click, click again while the wheel are up?
Guys should I change my wheel bearings also with them having 150,000 miles?
Thanks,
Mike
Old Jan 31, 2005 | 09:58 AM
ddrumman2004's Avatar
ddrumman2004
The joints, as a rule, only click with a load on them and yes...I would replace the bearings also. It's better to be safe than sorry with that many miles on the drive train.
Old Jan 31, 2005 | 11:21 AM
1081's Avatar
1081
There is a slight chance it could be the hub caps also (if it has them) and you can pull them off and then drive it to tell. I would tend to agree that it is probably the cv joints and they wouldn't necessarily been notice during an alignment unless the boots were torn and greasy. You can get parts to rebuild them but it is quicker and much cheaper to just get short shafts (pre-assembled rebuilt) and put them in.
Old Jan 31, 2005 | 12:26 PM
muscletruck7379
toss it onto the lift and with it in park try to spin the tire back and forth and listen, then turn the wheels all the way and do it again. you will need to disconnect the lower control arm, tie rod, sway bar, etc. and be prepared to really grunt on that axlenut! good luck!
Old Jan 31, 2005 | 01:41 PM
SSCX2's Avatar
SSCX2
Easy job, I doubt the hub bearings are bad.
Old Feb 4, 2005 | 10:43 PM
mike L's Avatar
mike L
Cv boot was torn so I had it replaced. I can still here a noise when turning right a low sound thump, thump. I wounder if its brakes or the springs??? Pads are ok for now shocks are new. I did noticed that there a plastic boot that slides up and down on the strut maybe that the noise. I don't remember the old struts had this black plastic cover with ridges over the struts, the part doesn't look new though. The neighbor has a van like mine ill check her van. Any thoughts on what the noise is? Front end was check to.
Old Feb 4, 2005 | 11:55 PM
muscletruck7379
it doesn't take much driving to ruin a joint that has a split boot. although if the sound isn't major you might still have a few more miles on it. my neighbors geo went for hundereds of mile with that joint clicking away!
69oiler
Oct 29, 2017 08:11 AM
ctfl
Jul 29, 2010 11:50 PM
masterleo
Jul 11, 2010 04:10 PM
BroncoPimp94
Feb 9, 2010 06:45 PM
scottspoerry
Apr 11, 2005 03:41 PM
