Back Firing
Old May 25, 2002 | 11:01 PM
seymour's Avatar
seymour
Back Firing
Drove my 1984 f-150,302 2 barrel, about 60 kms today and when I shut her off it back fired. What could cause this problem. Any help would be appreciated. This is not the first time this happened.
Old May 25, 2002 | 11:12 PM
Mil1ion's Avatar
Mil1ion
Back Firing
[updated:LAST EDITED ON 26-May-02 AT 00:12 AM (EST)]Did it back fire out the exhaust or out the carb ?
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTE Moderator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 26, 2002 | 01:50 AM
seymour's Avatar
seymour
Back Firing
Out the exhaust.
Old May 26, 2002 | 02:13 AM
seymour's Avatar
seymour
Back Firing
Replaced the plugs,wires and rotor button just recently.
Old May 26, 2002 | 09:48 AM
rocky2's Avatar
rocky2
Back Firing
try taking the air pump belt off and see if it stops backfiring.
Old May 26, 2002 | 02:42 PM
seymour's Avatar
seymour
Back Firing
Already removed belt a while ago.
Old May 26, 2002 | 04:41 PM
Franklin2's Avatar
Franklin2
Back Firing
Does it have an unusually smelly exhaust? That could be from it running a little rich, maybe from a power valve in the carb with a hole in it. Unburned fuel in the exhaust from a rich condition could cause a backfire.
Old May 26, 2002 | 07:55 PM
seymour's Avatar
seymour
Back Firing
Where is the power valve located.
Old May 26, 2002 | 08:50 PM
quads's Avatar
quads
Back Firing
its inside the carbuator
Old May 28, 2002 | 01:02 PM
Franklin2's Avatar
Franklin2
Back Firing
On your motorcraft type 2bbls, it's under the front of the carb, behind a plate with four screws. On the front of the carb there is a plate with four screws and a lever. This is the accelerator pump. The power valve plate looks just like this, only no lever and you have to take the carb off to get to it. If when you take the plate off, if it's wet with gas, it's a sure sign the valve has been leaking, since under the cover should only be vacuum. The fuel should be only on the other side of the valve up in the fuel bowel.
Old May 28, 2002 | 03:57 PM
perryphilip's Avatar
perryphilip
Back Firing
[updated:LAST EDITED ON 28-May-02 AT 04:59 PM (EST)]where is the power valve located on the 351ho 4bbl? i have a sudden problem with my engine running very rich and i suspect its the power valve. How hard are they to replace?
thanks
1985 Bronco XLT, 351HO 4bbl, C6, NP208 ,9" 3.55 limited slip, Warn Premium Hubs, Quad Front Shocks, Dual Flowmaster 50's, BFG 32x11.5 ATko's
Old May 29, 2002 | 04:58 PM
Franklin2's Avatar
Franklin2
Back Firing
I am assuming your HO has the Holley type carb. This one is up inside the carb. But I believe you can get to it without having to take the carb off if you don't want to.
Put a towel on the intake manifold under the front of the carb, and take one of the lower four bolts loose on front of the carb. Gas should pour out till the fuel bowel is drained. Take the rest of the bolts out and pry the front of the carb off. It should be a large piece (fuel bowel), and a smaller piece (metering block) that comes off. The power valve is screwed into the back of the metering block. But the fun has begun, since now you have to scrape all the old gaskets off. I know advance in my area carries the gaskets and power valve you need seperately without having to buy a whole kit. When you put it back together, watch out for the o-ring on the fuel tube on the side of the carb. Put a little oil on it before you put it back in, and it would be nice if you could buy a new o-ring too.
Old May 29, 2002 | 05:48 PM
Franklin2's Avatar
Franklin2
Back Firing
