Component identification needed
Old Jan 30, 2005 | 07:42 PM
dgeist's Avatar
dgeist
Greetings. I have a 1988 E150 with an EFI 5.0. There's a component that I'm thinking of reloacating to do some cleanup/mods and I'm not sure what it is/does.
The part is mounted to the driver's side radiator core support immediately adjacent to the horn. It has what appears to be a vaccum line or cable running from its side (the middle of a round, flat section about 4" in dia.) to the top of the throttle linkage. It also has a harness that connects from its bottom and runs down along the fenderwell towards the firewall. What is this component and what considerations should I make for any reloacation/replacement work.
Thanks,
Dan
Old Jan 31, 2005 | 11:28 AM
loudfords's Avatar
loudfords
Do you have a picture? It sounds like the charcoal box that filters gas fumes from the fuel tanks. The vacuum line to the throttle body is for purging the box.
Old Jan 31, 2005 | 04:01 PM
dgeist's Avatar
dgeist
I know it's not the charcoal box. That's located on the passenger-side frame-rail about half-way back on the frame. This contraption looks like a mini-master-brake cylinder, but only connects to the throttle body and the wiring harness. I'll try to post some images later.
Dan
Old Jan 31, 2005 | 05:02 PM
EPNCSU2006's Avatar
EPNCSU2006
Sounds like it is the cruise control servo.
Old Jan 31, 2005 | 05:07 PM
dgeist's Avatar
dgeist
Bingo! That must be it. I don't know why I didn't think of it before. What else touches only the throttle and the eletronics
Dan
MrFord619
Nov 14, 2016 09:57 AM
Richwon4
Jun 8, 2016 01:31 PM
demolitioniskey
Aug 25, 2014 04:57 PM
NetCommuter
1997 - 2003 F150
Jul 19, 2009 06:42 PM
