alignment
Old May 31, 2002 | 09:13 PM
olddawg's Avatar
olddawg
alignment
I replaced everything from one outer tie rod to the other,axle pivot bushings,lower ball joints.The suspension on this truck was so far gone.I counted threads on the old parts to make sure they were installed close to correct,but now this thing goes down my dirt road and wants to visit the ditch.Any suggestions on how to shadetree align so I can get it to the shop?
Old May 31, 2002 | 10:01 PM
paveslave's Avatar
paveslave
alignment
Measure the middle to middle of your rear tires and then use that measurement to align the front. It wont be perfect but it'll get you on the right track. Disconnect the front tie-rods on both the left and the right knuckles. Kick your tires to where your front tires middle tread is where you measured the back. Now, adjust your tie-rod ends to fit into the knuckles without moving the wheels any to make them fit. Snug them down and you should pretty much be aligned, enough to make you happy anyway. Good luck, and yes I've used this method before and it works, in the "shade tree" market anyway
-Ry
1985 F-150 302 4X4
Dana 44 TTB / 9 inch
4.56:1 Front/True-Trac
4.56:1 Rear/Detroit Locker
C-6 Tranny, NP208 Transfer
6 inch Skyjacker Class II lift
35 X 12.50 BFGoods AT's
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3725&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3536&.jpg
Old Jun 1, 2002 | 08:22 PM
olddawg's Avatar
olddawg
alignment
[updated:LAST EDITED ON 01-Jun-02 AT 09:23 PM (EST)] Big help thanks.still needs alignment but at least now it won't eat all the rubber off before I get there.
Old Jun 1, 2002 | 09:52 PM
paveslave's Avatar
paveslave
alignment
