starter question
Old May 31, 2002 | 06:55 AM
cj7taz's Avatar
cj7taz
starter question
recently swapped in a 79 c6 automatic into my 86 f150 4x4. i have a 302 with efi. my question pertains to the starter. can i use the same starter that i used with the 4 speed with the automatic.
naturally i had to change the flywheel plus a bunch of other stuff.
Old May 31, 2002 | 10:06 AM
Greywolf's Avatar
Greywolf
starter question
It should fit with no problems, as long as the flyplate is right for the engine.
Old Jun 1, 2002 | 06:44 PM
rocky2's Avatar
rocky2
starter question
If it makes any kind of noises while starting its not the right one.
Old Jun 1, 2002 | 09:52 PM
paveslave's Avatar
paveslave
starter question
When I swapped out my NP435 for my C-6 I had to use a different starter. I don't know if it was just the dust shield that made it not work or what, but it wouldn't fit. Fortunately I had the starter on hand and the only difference between the two was the length of the starter housing that cases the gear, it was longer. I can't remember which one was longer though, sorry. Well, hope that helps.
-Ry
1985 F-150 302 4X4
Dana 44 TTB / 9 inch
4.56:1 Front/True-Trac
4.56:1 Rear/Detroit Locker
C-6 Tranny, NP208 Transfer
6 inch Skyjacker Class II lift
35 X 12.50 BFGoods AT's
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3725&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3536&.jpg
Old Jun 2, 2002 | 09:10 AM
brknfrd's Avatar
brknfrd
Post starter question
