Installing engine block heater
Old Jan 30, 2005 | 01:46 PM
msjuhlin's Avatar
msjuhlin
Hey all. I spent some time looking through lots of posts but didn't find my situation. I bought an engine heater for my '00 Ranger 3.0. Its the external tank type that heats and circulates the antifreeze. I'm trying to decide how to run the inlet (get antifreeze into it.) There's a couple different options in the instructions. #1 is to cut up my lower radiator hose and put a T in it. NO WAY! The other options are to thread a tap into the radiator drain (not likely with this plastic stopcock stuff) or to tap one of the engine block drains. I'd like to do the latter. Does this truck have block drains? Can't see 'em anywhere. Checked Haynes and Chilton, don't know why I bother. Or if you have other recommendations, I'd really appreciate hearing it. Thanks
Old Jan 30, 2005 | 03:16 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 30, 2005 | 03:21 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Welcome to FTE!!!
Have you looked on the sides of engine block where the oil pan bolts to it?
Old Feb 1, 2005 | 09:18 PM
msjuhlin's Avatar
msjuhlin
Yup, but I couldn't see very much. I can see the freeze plugs on the passenger side but not much else. I tried to feel for any bolt heads but its too darn cold out!
AMG-SM
29
Sep 9, 2019 11:47 AM
SEH43
Jun 23, 2013 01:45 PM
MarkMoore
Modular V10 (6.8l)
16
Jan 9, 2008 07:00 PM
brown 4x4
Nov 29, 2007 06:45 AM
holland501
Dec 11, 2005 06:23 PM
