i have replaced tensioner bearing, my water pump and the vacumm pump and im getting a progressivly louder bearing noise from the alternater or power steering pump?..i change the power steering pump fluid all the time...i thought i'd spray each one at a time till noise stops to diagnose this...or take belt off and feel for play? ..any suggestions? i have just over 100,000 miles on it
thanks in adavance
Reason: fogot to put mileage
Have you changed your belt? Mine was chirping really loud and I changed the serpentine belt. Solved the problem. Sounds like you changed everything but that.
ya i changed the belt too a couple years ago...me and my buddie were lookin at it again yesterday and it seems to be comin from the vacumm pump i just replaced 4 mo's ago...in the meantime were waiting for it to stop raining b4 we proceed any further...the noise yesterday was notthere at start up cold but got louder as it warmed up
I bet it is still your belt even though you just changed it a couple of years ago. Don't know why but I have replaced mine about 4 times for the same reason...crickets!!! 1995 has only 125000 on it, so thats about every 30k.
Welllll... thought I was the only one. I too have those same crickets! I opened the hood the other day but the engine noise drowns it out. I also notice it goes away after the engine warms up, especially on colder mornings (SOCAL cold that is 35F).
Maybe I'll try the belt, easy fix.
