Won't Charge Help!
Old Jan 30, 2005 | 12:47 PM
npayne's Avatar
npayne
Unhappy Won't Charge Help!
1983 Ford F100 with a 351. Changed the regulator, alternator, checked all the wires around the battery area. the alt. tested before i took from store tested at 12 volts checked all the fuses and fuseable link all appear fine. Not getting any power back from the alt. so i changed all the wires to the regulator. still nothing
Old Jan 30, 2005 | 03:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 30, 2005 | 05:50 PM
Peter94's Avatar
Peter94
My 85 F150 charging problem was fixed with a regulator. did you make sure it was grounded (mounted) before you plugged in the wiring harness? Also, maked darn sure that all the wires in the regulator harness are tight. ONe was loose on my 150, and it wouldnt charge anything. The best thing you can do is get a multimeter, hook it up to your battery, start your truck, and start wiggling wires on the harness until you see the voltage jump up to where it should be. There was also a wire disconnected on my truck too.
Old Jan 30, 2005 | 08:29 PM
npayne's Avatar
npayne
i thought about that and changed all the wires going to the regulator. but i will double check them thanks peter94
Old Jan 30, 2005 | 09:02 PM
npayne's Avatar
npayne
checked all the connections, all were tight. the only way i can get to charge at all is to put wires on wron and then it over charges.
Old Jan 30, 2005 | 09:49 PM
Ford84's Avatar
Ford84
I've been having the same problem with my 1984 F-150. I've replaced the alternator and the battery. I do not know what i should do next and I don't really have the money to keep replacing things that arent broken. Any help?
Old Jan 30, 2005 | 09:56 PM
Peter94's Avatar
Peter94
hmm, exactly what voltage is it charging at? also, on the regulator, i believe there is a yellow wire, and it hooks to a green wire, which goes to a little metal thing that screws on where your regulator screws on. Make sure that is connected, mine wasnt, and it wasnt charging either.
Old Jan 30, 2005 | 10:08 PM
npayne's Avatar
npayne
Thumbs up
i changed the wire around its not the way the harrness was but it is charging at 13 to 15 volts so i guess that will work? i hope! as long as it dosn't burn anything up. thanks for your help!!
Old Jan 30, 2005 | 10:10 PM
Peter94's Avatar
Peter94
as i believe, it should be charing around 13.5 volts. 15 sounds a little high, but maybe not. What does your voltage thing read inside the truck?
Old Jan 30, 2005 | 10:12 PM
npayne's Avatar
npayne
that is inside the truck. i don't have a volt meter here my step son has one at his house.
Old Jan 30, 2005 | 10:21 PM
Peter94's Avatar
Peter94
Yeah, with the needle right in the middle, my truck is charging at about 13.5 volts. I would get a multimeter for yourself, you can get a decent one for about 30 bucks, i got mine at radioshack, and have used it hundreds of times. You can use if for continuity testing, volts, amps, etc. Or just wait till your step son comes down and test it then, because the one in your truck really doesnt tell you alot of exact information
Old Jan 31, 2005 | 06:33 AM
npayne's Avatar
npayne
ford 84 make sure the alt. and regulator is still good have them tested to make sure, that is the first step. a new regulator should only be around $11
Old Jan 31, 2005 | 10:26 AM
Chuky66's Avatar
Chuky66
I wired-in a 130 amp alt off a 93 Taurus, with internal voltage regulator on my 86 F250. Works great, and got it fot 30 bucks at wrecking yard, with a few wires I needed.
Chuck
Old Jan 31, 2005 | 07:58 PM
TUFFY's Avatar
TUFFY
Chuck
How did you wire this up? do you have a diagram on this that you could post? thanks Dave
Old Feb 1, 2005 | 12:08 AM
Chuky66's Avatar
Chuky66
http://www.fordfuelinjection.com/pub...ALT_wiring.gif
this is what I used, and one from someone here on the board. I forget who? I bet someone in electrical will have another diagram that might help.
If I can be of any assistance, drop me a line.
chuck
