Valve cover gaskets
Old Jan 29, 2005 | 10:48 PM
881504x4's Avatar
881504x4
Valve cover gaskets
I have an 88 F150 4x4 with a 5.0. i have to change the valve cover gaskets. does anyone know any tricks, tips or hints?
<!-- / message -->
Old Jan 29, 2005 | 11:50 PM
ghostflamed66's Avatar
ghostflamed66
the only think that comes to mind would be to use rubber gaskets insted of cork.
They cost alittle more but they are well worth it. I have always had trouble with cork wanting to smash out of cover,even when using the correct torgue spec.
Wes
Old Jan 30, 2005 | 08:12 AM
KcinMI's Avatar
KcinMI
I agree, the silicone rubber gaskets hold up far better than cork, especially when you have to remove your upper air intake to replace the right gasket.
Old Jan 30, 2005 | 08:38 AM
pfogle's Avatar
pfogle
Get the really expensive ones with the metal inserts around the bolt holes. You CAN'T squash them out.
Old Jan 30, 2005 | 11:20 PM
tbirdscott's Avatar
tbirdscott
If your valve covers are tin flip them upside down and use a ball peen hammer to tap the bolt holes back out since they are likely bent from the force of the bolts holding them down.
Old Jan 31, 2005 | 03:13 PM
snoman's Avatar
snoman
don't over tighten the bolts. if you are going to use short bolts; use a socket with a extension, no ratchet, and only get them hand tight. i used some of the long bolts and didn't need a socket for them.
again, the key is to not over tighten.
