Offroad & 4x4
transfer case ?
Old Jan 30, 2005 | 01:17 PM
matt77F2504x4's Avatar
matt77F2504x4
i cant tell you guys how much i appreciate your help! thanks to all of you!
this truck was bought and is being built to be a mild off roader and to get me to work and back. i got it two years ago, for $100.00. sezed engine, mangled tranny. i think someone towed it over a hundred miles IN GEAR! now the 351m has 10,000 miles on it, reman. tranny, rebuilt t-case, new brakes, new steering gearbox, new front driveline, oh yeah, new CB, (im a radio junkie!). now its time to get the suspension happening. its showing its age, and im afraid to do any real wheeling until i get new ball joints and some new polyurethane bushings. im interested in any advice you guys can give me on how much of this i can do in the driveway and what i'll need a shop for. ive been wrenching on cars, (no 4x4's though) since i was 12, (holding wrenches for dad.) so im not daunted by a set of instructions. i just dont want to buy tools that i'll only use once or twice. thanks again for all the help.
P.S. my truck has the four leaf spring suspension if that helps anyone.
Old Jan 30, 2005 | 01:24 PM
f-4x4's Avatar
f-4x4
how much did it cost to put new bearings in your trans and transfer case
Old Jan 30, 2005 | 08:14 PM
matt77F2504x4
i'll have to check the invoice, but i dont think it was more than 200 dollars. of course everything was already taken apart for the 1400 dollar tranny job.
i did the turn the driveshaft trick, and im am in 2 wheel drive. my t case seems to want to go from neutral (where i leave it for normal driving), it goes one click back. from neutral it will go all the way forward and then when i pull back on it it seems to find another gear just forward of neutral. thanks again for the help.
Old Feb 2, 2005 | 07:18 PM
4x4kinda girl's Avatar
4x4kinda girl
the np 205 should have a shift pattern as follows: all the way forward(towards dash) is 4 low, one back from that is neutral, then 2 high (normal driving), and all the way back towards the seat is 4 high , if you give the trans code off off the id tag i will tell you what trans you have?
Old Feb 2, 2005 | 08:35 PM
matt77F2504x4
you got it! give me a day or two as i am in the process of moving. im gonna have a garage!
acm05fsu
1997 - 2003 F150
19
May 1, 2010 09:56 PM
John Michele
Aug 23, 2009 07:10 PM
Wild Karrde
Mar 17, 2007 07:57 AM
jcor
Dec 30, 2003 12:41 PM
Hallmarkreno
Jun 12, 2003 04:13 PM
