'76 Noisy/vibrating transfer case/gear shift levers
Old Jun 10, 2003 | 10:29 PM
Hallmarkreno's Avatar
Hallmarkreno
I'm new to the forums! I'd like some advice/help. My "new to me" '76 F250 4x4 (390, NP 435, Dana 60) has noisy gear shift and transfer case shift levers. They "growl" when I'm driving. A local transmission shop said it's normal for the NP 435, there are no insulating bushings and I should just wrap the levers in foam. Is this correct? I can push the transfer case lever about 1/4 to the left and the noise stops... Engine and trans are strong, no problems other than the noise.
1976 F250 4x4
390 2bbl
NP 435, Dana 60
Old Jun 11, 2003 | 01:58 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Hallmarkreno, the transmission guy may be right. I've tried to solve my shifter vibration for years (NP435). Everything has been tried; wheel balancing, driveshaft phasing, new transmission and transfer case mounts, fluid change, etc, etc. All this seemed to help a little, but nothing stopped it entirely.
Instead of wrapping foam around it, try cutting a piece of heater hose to length, and insert it on the shifter handles. This will dampen out the vibration, and looks better than tape and foam.
Old Jun 11, 2003 | 02:02 PM
73Custom's Avatar
73Custom
I use foam insulation for 1/2" copper pipe (about $2). Just unscrew the handle and slide it down the shifter. It's black so it looks like it belongs there.
Marty
Old Jun 11, 2003 | 10:52 PM
Hallmarkreno
Thank you for the suggestions - I'll see how much hose and foam it'll take to make it bearable!
'76 F250 4x4
390 2Bbl
NP435
Old Jun 12, 2003 | 04:13 PM
Scot's Avatar
Scot
There are two split plastic bushings on the t/c pivot bolt. They may need replacement. I put a long brake spring underneath between the shifter and frame to hold some tension. It eliminated the buzzing noise.
ranscobia
Apr 1, 2018 02:49 PM
Ruffasacob
Dec 1, 2015 06:18 PM
351coupe
Ford Truck Parts for Sale
71
Nov 13, 2015 05:23 PM
hockeyguy1134
May 25, 2014 08:08 PM
MNTBUGGY
Apr 3, 2012 12:56 PM
