brake conversion
Old Jan 29, 2005 | 09:27 PM
ford390gashog's Avatar
ford390gashog
brake conversion
i want to convert the brakes on my 75 f-150 to 75 f-250 brakes so can i just use a f-250 caliper and rotor and hub up front and swap the axle out back
Old Jan 30, 2005 | 12:43 AM
cseastaugh's Avatar
cseastaugh
I'm doing a similar thing right now. Things to be wary of are....
1) The f250 spindles are longer, but inner axles are different so you'll have change them at the uni. That's assuming you're using D44 F250 parts, otherwise you might be in strife.
2) You'll have to change the brake master cylinder.
3) The original F250 hub seals (with a locating flange) are listed as 'no longer available' parts -in Australia anyway.
4) 15 inch rims won't fit over the big calipers.
5) Longer spindles will make your track about 1/2 inch wider each side. With wide tyres you may need to look at beefing up the steering damper. I haven't got that far yet.
6) Rear tailshaft will need to be shortened about 3 inches.
Have fun!
Old Jan 30, 2005 | 03:44 AM
GeneStoner's Avatar
GeneStoner
Consider the brake conversion in the Tech articles by Danny Cabral. According to him, you actually get a BIGGER overall piston with the T-Bird caliper over the F-250 ones...
I did it, and I like 'em.
Old Jan 30, 2005 | 11:25 AM
beeboy's Avatar
beeboy
doing the booster upgrade made the biggest difference on my 79. I also did the tbird calipers, and SS hoses. She stops nice now!
Old Feb 7, 2005 | 03:16 PM
progt1's Avatar
progt1
Amen Brother
I added the f250 booster and master cylinder, tbird calipers, and 1 ton real wheel cylinders. The brakes are fantastic. They weren't anywhere near this good when the truck was brand new!!!
Old Feb 7, 2005 | 03:38 PM
hawkrod's Avatar
hawkrod
Are we talkin about a 4X4 or a 2 wheel drive here? Big difference. Hawkrod
Old Feb 7, 2005 | 03:59 PM
progt1's Avatar
progt1
Mine's a 78 Bronco
Old Feb 8, 2005 | 12:49 AM
GeneStoner's Avatar
GeneStoner
The conversion talks about 5-lug front ends for 78-9 Broncos & 73-9 Trucks. 2 & 4wd.
