It's quite possible that I will be buying an '86 Bronco in a week or less. I just need to set everything up. So I was curious if they had lightbars for the Bronco? I looked at 4wheelparts.com and didn't see anything. Although I haven't checked Jegs or Summit yet. Anyone know of any?
>Also I'm wondering if it's possible to swap in a 4 speed
>NP205(?) manual into a Bronco and if it is, how hard is it?
Shouldnt be to hard, i think you could get the 4 speed in a bronco (you could get it with a F-150)... NP205 i belive is a transfer case, the bronco should have the NP208 already, if you have the 4 speed tranny with matching trasfer case at the most you would have to make some linkage and i doubt it, but possibly different driveshafts....
