Bronco II Ford Bronco II
windows fogging up
Old Jan 29, 2005 | 07:54 PM
CrazyFazy's Avatar
CrazyFazy
windows fogging up
I have a 88 bronco2 and it seems like ever since i owned it the windows have fogged up badly. The heater works great but the side windows in the front and rear get to where you cant see out of them. I have to put the window down in order to use my mirror. The windshield even wants to fog up unless i have the defrost almost on high. This is getting to be a driving hazard and the only way i can back up is to open the drivers door. Where can all this moisture be coming from? The other day i actually had to scrape the INSIDE of my windshield. I am not sure if i removed the bags of insulation on either side of the cowl but i will check. Anyone think this could cause this problem or have any suggestions? Thanks.
Old Jan 29, 2005 | 08:00 PM
Ken00's Avatar
Ken00
Sounds like a leaking heater core to me.
Old Jan 29, 2005 | 08:04 PM
SquatchMobile's Avatar
SquatchMobile
Same here. Crazy, wipe off a big area of fog from the windsheild with your bare hand- if it feels slightly oily, it's your heater core.
-Sarge
Old Jan 29, 2005 | 08:23 PM
CrazyFazy's Avatar
CrazyFazy
Guys i am going to check for that tomorrow. It really doesnt use much fluid just a drop or two every now and then. This is a good suggestion though and one that i totally missed. What is involved in changing the heater core on this? It has been so long since i did any work to this i have totally forgotten if its located inside behind the glove box or not. LOL.
Old Jan 29, 2005 | 11:54 PM
bronco2man's Avatar
bronco2man
Unhappy
sounds like a heater core problem, had that problem at one time in my 88 bronco II
Old Jan 30, 2005 | 07:27 AM
DJ_FX's Avatar
DJ_FX
mine had a lot of moisture in it, i just put it in the garage and im going to barrow a dehumidafier from my neighbour when it warms up. the bronco is prone to leaks, water can get in, make its way to the driver and passenger floor, then evaporate. and it could also be the heater core as everyone said.
actually, dosent the heater core have engine coolent in it? that stuff isnt supposed to freeze. also, if the heater core was leaking, you would smell it when the heater is on.
my 2 cents is that your best bet would be to park it in a warm garage and run a dehumidifer in it with the windows closed
Old Jan 30, 2005 | 07:33 AM
SShank42's Avatar
SShank42
Mine does the same thing. Mine is not the heater core. It get water on the floorboard from leaking windshield and then when it starts to warm up inside the vehichle it forms condisation on the inside of the windows.
Old Jan 30, 2005 | 04:11 PM
Ken00's Avatar
Ken00
The heater core should be 4 bolts under the passengers dash, the hose clamps, easy job.
Old Jan 30, 2005 | 04:14 PM
LILBLUE04FX4L2's Avatar
LILBLUE04FX4L2
your truck has a leak
find the leak and your problem will be solved
HRTKD
Mar 6, 2017 10:28 AM
vtjvt
Nov 29, 2016 06:27 PM
xaviar
Jul 19, 2016 01:45 PM
Karnivool
16
Feb 10, 2016 05:11 AM
forager
27
Aug 6, 2014 04:36 PM
