Why do my directionals not work?
Old Jun 7, 2002 | 01:13 PM
KRMFiero's Avatar
KRMFiero
Alright, 83 ford f-150.... i changed the flaser and fuse, all bulbs apear to be good... they just dotn blink or anything... my harards work though? what could it be? what should i replace?
Old Jun 7, 2002 | 01:21 PM
Franklin2's Avatar
Franklin2
Verify that all the bulbs are lite. Flip the signal lever and get out of the truck to make sure the front and the rear lights are lit. They all have to be burning or the circuit will not draw enough current to make the flasher work. You must have not bought a heavy duty flasher, because that type will blink regardless if a bulb is out or not.
Old Jun 7, 2002 | 02:08 PM
Mil1ion's Avatar
Mil1ion
There are TWO flashers.
One for the hazard lights and one for the signal lights.
You said the hazards work.
Turn them on and feel the flasher on the fuse box.
You should feel it click.
The signal light flasher is on the BACK of the fuse box.
You need to remove the fuse box and replace the T/S flasher.
[font color=red]Dennis
Calgary,Alberta,Canada[/font]
[link:www.ford-trucks.com/guidelines.html|FTEModerator]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jun 7, 2002 | 02:19 PM
KRMFiero's Avatar
KRMFiero
Alright, i swapped fuses with my hazards, turn signals still dont work - hazards do still with the turn signal flasher.... my lights dont light up when i flip the switch at all ( i think they did and stayed on when i fist got the struck, but now nothing....) ?
Old Jun 7, 2002 | 03:15 PM
Franklin2's Avatar
Franklin2
I don't have my wiring diagrams with me, but if the lights flash with the hazard circuit, we will assume the wiring and such is good out at the lights themselves. The only thing I can think of would be something unplugged in the column. Maybe somebody that has there wiring diagram can look to see how the hazard circuit joins itself into the turn signal circuit.
Old Jun 7, 2002 | 03:22 PM
topo4u2's Avatar
topo4u2
Check your brake lights and see if they work first. Then wiggle the signal arm a little and see if the green arrow indicator comes on at all ...make sure key is on! If you have no brake lights then it is likely that you have a bad signal switch. Does this truck have a tilt wheel by chance?
Old Jun 7, 2002 | 04:38 PM
KRMFiero's Avatar
KRMFiero
I was told my brake lights work (may of been just the sun though) but the green indecator lights do not come on, it is not a tilt wheel
kyle
Old Jun 8, 2002 | 09:53 AM
topo4u2's Avatar
topo4u2
Please check your turn signal fuse and make sure those brake lights work. If all else fails I would personally look at a signal switch problem.
Old Jun 8, 2002 | 07:41 PM
olddawg's Avatar
olddawg
all the above answers are good,however the first thing I always check
is for is a good ground.
Old Jun 8, 2002 | 07:50 PM
pancake's Avatar
pancake
