carb problem
Old Jan 29, 2005 | 05:55 PM
chopz1o1's Avatar
chopz1o1
Unhappy carb problem
ok where do i start 91 ford f 150 xlt swb 4.9 six
i bought this truck for 1000 bucks this is how it was
they have removed the throttlebody
and replaced it with a carter motercraft carb
and whatever manifold is on it
started out with one bad oil leak
found that it needed a new valve cover gasket
that was fixed and changed the oil to shell rotella 15 40 t
and fram PH8A
then after doin that notied that the carb was flooding out
spewing gas out of a couple places after it idled down
i have pics showing where its coming from theres a little
port on the bottem of the bowl on the left front
i would like to get everything back to orig
but i fear that that would cost to much
my mech said i need to replace the stock tranny with a c6 i think he said
if i was to keep this setup
my question is should i try to get this carb rebuilt of look for a diff one???
any help would be appreciated
Old Jan 30, 2005 | 03:44 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Brian Goodman
May 31, 2016 09:32 PM
The Terrible Blob
28
Sep 6, 2014 11:16 AM
DoesItReallyMatter?
85
Apr 23, 2014 07:32 AM
crazed87bronco
Feb 7, 2012 08:08 AM
rbhadams
15
Sep 9, 2011 06:48 PM
