Steering wheel replacement
Old Jan 29, 2005 | 04:09 PM
Icicle's Avatar
Icicle
I have a new grant Steering wheel for our 82, and the appropriate installation kit.
Ive never done a steering wheel before, is this a simple project, or a PITA?
Anything to know before I tackle it?
Old Jan 29, 2005 | 07:00 PM
UglyTruck's Avatar
UglyTruck
I am assuming that you do not have cruise control...
This is a piece of cake as long as you have a steering wheel puller... 1/2 hour tops
Ugly Truck
Old Jan 29, 2005 | 07:50 PM
Beast12's Avatar
Beast12
It's actually really easy. You don't even NEED a steering wheel puller if you are strong!
First turn your steering wheel so your 2 front tires are facing straight.
Take the middle cover off the front via 2 screws on the back.
There is a big nut underneath that cover that you will need to take off. Loosen it about two full turns.
Now you need a friend for this unless you are strong. Get under the steering wheel with both your arms/legs and bang on the center stud (where the big nut is) with a hammer. It may take a few sharp blows but it will come off.
Good luck!
-Matt
P.S. That nut I told you to just loosen and not take off, will prevent the steering wheel from flying off in your face when it finally breaks loose.
Old Jan 29, 2005 | 08:49 PM
Icicle's Avatar
Icicle
Coll guys, thanks. I have a steering wheel puller, just wanted to get some tips before I tried it.
