asembly lube
Old Jan 29, 2005 | 02:40 PM
352 blue's Avatar
352 blue
Question asembly lube
What is the best assembly lube
Old Jan 29, 2005 | 02:48 PM
Steina's Avatar
Steina
CO River Rat
Blue -
I've used Sta-Lube with good results, but I'm sure any brand-name is fine. One tip - change your oil and filter after 50-100 miles, as assembly lube tends to clog the filter.
Steve
Old Jan 29, 2005 | 03:30 PM
rusty70f100's Avatar
rusty70f100
I used the CRC stuff (with graphite and moly) and my engine runs fine. It's there for buildup and the initial cranking until oil gets there. I change oil right after the cam is broken in, then at 100 miles, then at 3000 miles, then every 3000 miles from there on.
Old Jan 29, 2005 | 07:25 PM
kotzy's Avatar
kotzy
Lubriplate 100 on cam, engine oil on bearings and rings unless it's a shelf engine that will sit for some time, then I use Lubrplate on everything. Lubriplate is high in zinc which
new cams need.
Old Jan 29, 2005 | 08:06 PM
rusty70f100
Usually new cams are supplied with their own lube from the manufacturer, which is high in moly content. If it is supplied with the cam, by all means use it.
Old Jan 29, 2005 | 08:32 PM
Steina's Avatar
Steina
CO River Rat
Just remembered - GM sells an oil additive for newly rebuilt engines; don't know if Ford has a similar product.
Steve
Old Feb 1, 2005 | 06:00 PM
daerhldgs2's Avatar
daerhldgs2
lubriplate works great, and GM sells an additive called EOS which is a great assembly lube. In every (no exceptions ) case before an engine is started the dist must be pulled and use a electric drill and run it up to pressure. This fills the filter and oil galleries. After 45 min of running change the oil and filter and then again at about 100 mi. , then every 3000 mi.
Old Feb 4, 2005 | 02:35 PM
Annihilator's Avatar
Annihilator
Lucas Heavy-Duty oil stabilizer makes a good assembly lube for mains and rods. Clevite has what is called Camgaurd or Bearing Gaurd which is available through Napa. It is red in color and very sticky.
Old Feb 4, 2005 | 07:20 PM
monsterbaby's Avatar
monsterbaby
best I have ever seen or used is clevite camguard/assembly lube stays on the parts very well can be left in a engine that will be sitting for a long while before starting without having to redue it, and have seen several proffesional shops recommend, and use it for engines that they built.
btw it is available at napa, and alot better than lucas, or moly grease as both of them will run out of the bearings in a very short time of the engine sitting.
Old Feb 5, 2005 | 12:36 AM
Annihilator
STP can be used also, to me it depends on what parts your putting it on.
Old Feb 7, 2005 | 12:45 AM
bigblocksix's Avatar
bigblocksix
i use whatever comes with the cam and plain old white grease on the bearings. works fine for me
Old Feb 7, 2005 | 04:46 AM
2020's Avatar
2020
I've had good luck using just oil.I always prelube before start up and have never had any problems.I used STP a lot years ago and had good luck with it.
Old Feb 7, 2005 | 07:12 AM
smoke n tires's Avatar
smoke n tires
STP engine treatment, the best, its thick so it stays in place till engine gets hot and oil washes it out.
Old Feb 7, 2005 | 04:12 PM
ranchero77's Avatar
ranchero77
one more vote for STP. I do use what comes with the cam for the cam. everthing else STP.
Old Feb 7, 2005 | 07:43 PM
rainbowATF's Avatar
rainbowATF
I mix a pint of 10W30 with a tube of moly assembly lube (it's slow mixing) then mix this with a pint of STP. This special mix was devised because I couldn't make up my mind on what to use. I've used it on three engines so far with success. On cam I use the supplied lube.
