fender well liners
Old Jan 29, 2005 | 07:16 AM
mfd35's Avatar
mfd35
fender well liners
I saw a post about fender well liners for 05 250 a whileback. Are these available as thru someone other than ford?
Old Jan 29, 2005 | 07:26 AM
HeavyAssault's Avatar
HeavyAssault
Try 1stfordparts.com
Old Jan 29, 2005 | 07:44 AM
twoballsleft's Avatar
twoballsleft
I don't know about that, but you can order then here and the prices are pretty reasonable... https://www.1stfordparts.com/partscat.html
Here's the front rear ones for an 04...probably the same)...can't find the rear rear ones right now cause the site is down)
Rear Front Shields & Clips<O</O
<O</O
Rear Front side(RH-LH) sheild F81Z-9929370-AA
Clips (Need 4) N801603-S61 $0.48 each
Don't know what you can do for the front liners because of the coils the are probably differant than an 04(I'm sure they don't even make them)...I would get a nice piece of rubber, cut some out, drill holes in the liner and use the clips(above) to hold them in...that's basically all the are on 04's from the factory...
Here are the part #'s...(there actually listed for an eirlier excursion but fir the 04 SD perfectly):
Inner front wheel well flaps:<O</O
<O</O
YC3Z-16103-BA 4WD Left
YC3Z-16102-BA 4WD Right<O</O
Old Jan 29, 2005 | 07:54 AM
twoballsleft
Ok site is up but it dosn't show the parts for the rear shields...send them an email or call them and they will find the part for you...I've ordered tons of stuff from them and they are very helpful.
Old Jan 29, 2005 | 10:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Do we know for sure if the 04 fits the 05
Old Jan 29, 2005 | 10:19 AM
npccpartsman's Avatar
npccpartsman
suspension changes on the 05 would most likely make the liners different--besides, it's a ford thing
jetact's Avatar
jetact
(2ea) F81Z*9928370*CA Front left and right
(2ea) F81Z*9928370*AA Rear Left and right
(8ea) *389358*S Plastic push pins (2 per piece)
These are what I ordered for my 05 and worked fine.
Old Jan 29, 2005 | 01:13 PM
twoballsleft
Well there ya go...
Old Jan 29, 2005 | 04:22 PM
IB Tim's Avatar
IB Tim
Very cool...will these fit a DRW
Old Jan 29, 2005 | 04:31 PM
jetact's Avatar
jetact
I've read some guys did thier own thing on the DRW. They got a rubber mud flap and cut it down and it fit real well. I've also heard of the same thing on the Single Rear Wheel and it covers alot more. But I think factory at least looks normal, but what is really normal if it doesn't come with it.
Old Jan 30, 2005 | 03:36 AM
Maxium4x4's Avatar
Maxium4x4
Gee whizzzz.......no hood blanket, no fender liners.... what do you get for 40 plus on an 05?
Bean Counters......
Old Jan 30, 2005 | 08:21 AM
IB Tim's Avatar
IB Tim
Did any year DRW ever come with liners...??
Azuretruck
Sep 7, 2016 07:42 PM
kengarchow
Feb 3, 2016 09:58 PM
Buck268
2009 - 2014 F150
31
Nov 24, 2014 07:46 AM
n6nfg
6.7L Power Stroke Diesel
Jan 25, 2014 08:51 PM
Byram
15
Apr 24, 2013 12:10 PM
