Bronco II Ford Bronco II
How do you change the timing
Old Jan 27, 2005 | 01:16 AM
RomerB2's Avatar
RomerB2
How do you change the timing? I'm still a newbie with the engine on these things lol.
Old Jan 27, 2005 | 07:19 PM
Ken00's Avatar
Ken00
You also need a timing light, otherwise you won't know what you setting the timing at.
Old Jan 27, 2005 | 10:56 PM
RomerB2's Avatar
RomerB2
I have a timing light in my garage, but how do I know when it's timed right? Whats the sequence or what? I think I'm going to go buy a Haynes manual tomorow.
Old Jan 28, 2005 | 08:51 PM
Ken00's Avatar
Ken00
The ignition timing is set in degrees before top dead center. On the balancer on the crankshaft there will be little lines, some are number in the degrees. You will also see a pointer on one side, this is were you shine the timing light. Connect the timing light, power to the battery and the inductive pickup to #1 cylinder, passengers front one, make sure all wires are clear. Pull the spout connector, a little plug at the end of a wiring harness coming from the distributor, normally laying on the passengers valve cover. Start the engine up, warm it up, make sure idle speed is within specification. Now you shine the light and read the degrees BTDC. To adjust you loosen the hold-down bolt on the distributor ( engine off ) and turn the distributor while checking the timing. When it's to the specification turn engine off, tight bolt, recheck timing, plug spout in.
gabbie07
Alabama Chapter
Jan 24, 2017 10:11 PM
Visseroth
26
Oct 9, 2012 10:29 PM
BigTruk small feet
Apr 24, 2012 11:01 AM
XS29L9B
Feb 29, 2012 10:14 AM
bronco351
Apr 27, 2003 08:05 AM
