Engine Wont Start....help!
Old Jan 27, 2005 | 11:06 PM
RodneyJ428's Avatar
RodneyJ428
Unhappy Engine Wont Start....help!
I have a 96 Ford Explorer XLT. It has about 120,000 miles. I have never had any problems with it starting until now. Each morning when I go to turn the key, the engine cranks but will not start unless I pump the gas pedal. The engine will start but I cannot let off of the gas pedal until the engine is warm. If I do the engine will die. I have a fuel injected engine so I should never have to pump the gas pedal.
Also, if the engine cranks and starts without my help, the RPM is at about 1. If have to help it and let the engine warm up then it is about .5.
I have been to the garage about half a dozen times trying to fix this problem. And each time they think they have it fixed...it runs for a few days then the problem starts all over again.
I would appreciate any suggestions or comments.
Thanks,
Rodney Jones
Old Jan 28, 2005 | 07:19 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Jan 28, 2005 | 10:56 AM
mrshorty's Avatar
mrshorty
Has the IAC been cleaned/replaced?
Fuel pressure checked? Any gas ini vacuum line to fuel pressure regulator?
Old Feb 1, 2005 | 10:50 AM
zepols86's Avatar
zepols86
I am having this same problem. have you got an answer to the cause? i'm assuming it's the fuel pump. please advice if you have solved this problem.
thank you.
Old Feb 5, 2005 | 08:15 AM
dwcrews's Avatar
dwcrews
I had the same problem and I found that the sensor attached to the timing flywheel was dirty. I simply disconnected and reconnected and haven't had a problem since.
Old Feb 7, 2005 | 07:07 AM
zepols86's Avatar
zepols86
Thanks, dwcrews. it was the sensor. I had it replaced and changed the fuel filter. now it works like a champ.
